Here's the one I use. The Sound Devices USB Pre It has wonderful mic pre's,
a superior headphone amp and lots of input output options. See it at:
http://www.sounddevices.com/pr oducts/usbpremaster.htm USBPre Features
a.. Dynamic range greater than 106 dB (in 24-bit operation)
b.. Flat 10 Hz to 22 kHz audio bandwidth
c.. Exceptionally low distortion characteristics
d.. Two inputs accept microphone, instrument, line, or tape level inputs
e.. Input type is selected per channel - allowing two different signal
types simultaneously
f.. Phantom power (48 volt) for condenser microphones
g.. S/PDIF coaxial input and output
h.. Six-segment LED peak input meter
i.. High-power headphone monitor
j.. Mix control enables headphone monitoring of analog source audio,
computer audio, or a mix of both source and computer audio
k.. Phono (RCA) jacks connect PC AUDIO output to external loudspeakers or
preamplifiers
l.. Bus powering from the USB port eliminates external power sources and
batteries
m.. High-strength extruded aluminum chassis
n.. Compact dimension (4.4 cm H x 18.5 cm W x 10.0 cm D)
o.. Mac?? OS 9, Sound Manager compatible, OS X Core Audio
p.. Windows 98??, ME??, 2000??, and XP?? Wave audio and DirectSound compatible
q.. ASIO for both Mac OS 9 and Windows
Frequency Response:
(reference 1 kHz) 10 Hz - 20 kHz, ??0.5 dB (any input to PC recording) 10
Hz - 20 kHz, +/- 1.0 dB (PC source to PC audio out)
E.I.N.:
(mic inputs) -124 dBu min. (10 Hz - 22 kHz bandwidth, 150 ohm source, gain
control at 50% or more, 15 dB pad out)
Output Impedance:
PC audio -3.3k ohms, headphones - 20 ohms
S/PDIF Digital:
24-bit maximum input, 20-bit maximumhardware output (limited to 16-bit
output in Windows Me and OS 9 Sound Manager), sample rate and bit depth
selected by recording software and operating system
Sample Rates / Bit Depths:
Recording: 8, 16, or 24-bit at 32, 44.1, 48 kHz
Playback: 8, 16-bit at 5 to 55 kHz, will play back 24-bit sources at 16-bit
Master Clock:
(recording) PLL generated, low jitter
Metering:
input level at A/D converter, 6- segment, 30 dB total range, peak
responding, 0 dB on meter = 0 dB FS (0 dB referenced to Full Scaled Digital)
Phantom Power:
48 V through 6.8k W resistors, each mic input will supply 10 mA
Powering:
USB bus powered, 3 stage soft-start meets USB hot-plugging power
requirements, 5 V, 350 mA quiescent current from USB port, 5 V 500 mA max
THD+N:
(10 Hz - 22 kHz measurement bandwidth) 0.05% max. (any input to PC
recording, gain control at min., input driven to -6 dB FS) 0.009% max. (PC
audio output, 0 dB FS output, 100k ohm load) 0.05% max. (headphone output, 2
V rms output, 600 ohm load)
Output Clipping Levels:
(1% THD, Window
