Question about Sony DVP-NS315 DVD Player
Dvd tray stuck - Sony DVP-NS315 DVD Player
    Genius:
  • Sony Master
  • 1,054 Answers
There is a pin under the dvd drawer that needs to slide in a slot on the bottom of the drawer. See if it is in the slot correctly.
Posted on Jul 08, 2013
SOURCE:
Tip
My 2910 player has similar issue. The tray gets stuck on eject. Started with not...
1)just open the player
2)remove the rubber belt connecting the dc motor
3)you can open the disc tray now
4)if there are any dust particles or obstacles in the door way just clear them up by using the cloth(dry cloth preferred)
5)if you have any greasy material like vaseline,oil,etc then just put that in the door for easy movement of the disc tray
6)if needed change the rubber belt which is connecting the dc motor
7) just reconnect the rubber belt again and then just fit all screws that s all
what s more your player s disc tray will start ejecting like the previous how you were using..
any doubts you can reply me
i am always here to assist you
thank you
bye
on Jan 06, 2009 | Samsung DVD-V4600 DVD Player/VCR
MY BUTTON IS STUCK ON THE DVD-ROM TRAY. WHAT DO I DO?
if you look on the drawer for your dvd drive, you will see a little hole.If you push a pin in the hole the drawer will open.
Aug 20, 2012 | Computers & Internet
Dvd tray stucked
take the top off the dvd player and see if something is stuck in the player. also a little bit of vasaline on the dvd door tracks helps for ease of movement
Nov 20, 2011 | Televison & Video
DVD tray stuck in the closed position
Is it jammed?
Still has a CD/DVD still in it?
Is so try cycling the power to see if it will kick it out.
Otherwise it's most likely a hardware problem like a bad tray motor, broken gear, or perhaps a bad/stuck switch on the tray assembly.
If it's still under warranty, call the manufacture technical or customer support for a possible replacement.
Jul 20, 2010 | iLO DVDR04
Dvd drive is not working
Replace the DVD drive. They are inexpensive and it's not worth your time to try and fix this drive...
Feb 05, 2010 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Stuck DVD tray
Turn off the computer and then use the paper clip to open the DVD tray.
If this doesn't work, then something is jaming and stopping the tray from opening. In this case, remove the DVD drive and dismantle the drive (ie. remove the metal cover to reveal the internal components and remove the CD ot DVD disc.
If nothing works the the DVD drive is faulty and needs to be replaced, these drives are not expensive.
Jul 21, 2009 | HP Pavilion DV5234US Notebook Laptop
DVD Tray stuck open
the tray is not catching (underneath the tray is ridges). unplug the dvd player from the wall for 5-10 min...plug back up and give the tray a lite push while tapping the open/close button
Jun 17, 2009 | Yamaha DVD-C920 Multi-disc DVD Player
Won't power up. Disk stuck inside. Can i open that tray to rescue my rental?
take a small flat head and pry the door open if not the only other way is to unscrew cover and manually push tray open
May 13, 2009 | Panasonic DVDS97S DVD Player
Dvd tray won't open dvd stuck
I had this happen when someone put a DVD in the tray when there was already one in there. I managed to pry the tray out to retreive the DVD's, but when I closed the tray it was stuck for good. I wouldn't bother doing this because you'd probably have to take the player apart for it to work again anyway.
I took it apart and found that the gears were thrown off from the jammed tray. If you have some mechanical ability, you should be able to see where it is off track. Most likely you would just have to snap the gears back in place, hopefully none of them broke. Also, when you have it apart, you can manually open and close the tray part to assure that it's corrected.
Mar 08, 2009 | Aspire Digital AD-1000 DVD Player
Sony DVP-NS315 DVD Player Logo
70 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
