Our central air conditioner on top floor is suddenly shaking and shaking our chandelier below.
SOURCE: central air conditioner doesn't cool
Usually when a unit isn't cooling it is because one there isn't enough freon in the unit. Second there could be a compressor gone bad. Third there could be a circuit short out. It can be very simple and it can be costly. It just needs to be checked out by someone who has understanding in this area.Look for an affordable service man or company in your area whom most people may be using to come out and check it out for you. They would be glad to. They can let you know about what it might cost also. If you have understanding in this area you might do it yourself. I do most everything myself and it keeps alot of money in my wallet. But I have to take the time to do it.
SOURCE: Kenwood Central Air Conditioner
If the unit runs normally, no ice formed in evaporator and compressor suction or the unit is cold during operation then the system is normal.
- Check if the condenser is clean.
- Check if condenser fan motor work properly, check if the rpm. is normal.
- Check if the compressor amps. is normal.
- Check for out of range sensors/ thermostat.
- Check if the unit control is operating normally.
SOURCE: rv air conditioner leaking
I have the same problem....it is a negative pressure problem holding water inside the unit until it overflows the pan and runs into the duct system. why this occurs....I don't know....I cant find a problem with my air return, but as soon as you turn in off, the water comes gushing out the drains on the unit. I resolved this....temporarily....by twisting up a paper towel into a wick, and placing one end up into the drain tray, with the other end lying well out into the exterior case. This lets the water wick out and keeps the tray drained. I don't understand the problem and don't know what the permanent fix will be, except maybe cutting a hole and placing an intake vent directly below the unit.
SOURCE: Sunbeam floor air conditioner KY25/Y
Mine is cooling but I have a broken fan. If you're not going to use it sell it to me please. contact me at [email protected]
SOURCE: My air-conditioner is leaking a lot of water onto the floor.
You may jst have a stopped up draon or drain pan. If you can get to thesmall whole that it drain out of. **** it out with a shop vac. If you have one. Russ
