Back to:
Tags:
Samsung Pleomax PKB-7000X
Usb device is not recognized it has malfunctioned i... (by 9 users)
posted by Sravan590 on Aug 26, 2007
Usb device is not recognized it has malfunctioned i get this msg when i start my computer ....when unpulg the device for 5-6 times and again plug it....its working...whats the problem????they didnt give any drivers for this keyboard..and theres also no drivers for this device in samsungpleomax site...plz help me in this
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
8 Other Users Have The Same Problem
Comment by Guest, posted on Jul 04, 2008
Comment by Guest, posted on Jun 20, 2008
drive in not working with the ceedo program and it will not reg. it .
Comment by Guest, posted on Apr 24, 2008
ftrgtr
Comment by Guest, posted on Mar 10, 2008
pleomax webcam PWC-2100
my computer could not recognize the above webcam, tried several times to install the driver and run the apparatus but with no progress, could you please help before i give up.
aziz
Comment by Guest, posted on Feb 28, 2008
i have nokia mobile when i attahced with pc i received same mesg.but when i attahced another mobile same cable this is working properly. and also when i attached nokia mobile with other system mobie is working.
Best Solution
posted on Aug 26, 2007
Helpful (85)
Sakibanda
Rank:Master Master
Rating: 79%, 22 votes
it seems there is no problem with the drivers there is some problem with usb port i think,
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Usb device is not recognized it has malfunctioned i get this msg when i start my computer:
I don't want to Accept this solution
Solution #2
posted on Nov 01, 2007
Thanks for Trying (70)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i think that u have to uninstall all of the programs for the device if there are any...
and thn u have to install them again..
it worked for my webcam...
also i think this may happen because you might not safely remove the hardware???...
if so then always remove it safely otherwise the device will mess up.
hope i was of help.
Thank You!
Solution #3
posted on Aug 23, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
I still don't know how to solve the problem, can someone please help me wi th this?!
Thank You!
Solution #4
posted on Apr 21, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
aSame headache here...
It's just a "crappy" Samsung....
Thank You!
Solution #5
Not Rated (0)
Guest
Rating: 0%, 0 votes
It's just "crappy" Samsung....
Thank You!
Solution #6
posted on Mar 19, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
samsung should sort this problem i have two cd drivers and still no luck
Thank You!
Can you Help with these Keyboards and Mice problems?
Samsung Pleomax PKB-7000X (00807575012977)
Well i have a HP 4 button optical mouse. My OS is WinVista...
he perdido la clave para introducirla en la...
my sonyericsson k750i says malfunctioned when i connect it...
I am trying to find a download for a user manual for this...
Sometimes when i type keys like.."h",...
8 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 13, 2007
again the same problem, i don't think that the usb ports are the problem. i tested on multiple computers. who can help me please contact at : florin25_hkl@yahoo.com
Comment by MEETHUN JV, posted on Dec 05, 2007
yes yuo are rigth i have faced the same problem plz help me out.I am seaching in the net for the help plz help me out
Comment by Prozac4me, posted on Nov 07, 2007
I think this is a common problem, with this actual usb drive. I have browsed multiple forums, and see a common theme. "It was working, and now when I plug it in, windows (XP) does not recognize it." Consequently, when you peak in the device manager, it shows up. If you try to update the driver, you'll have no luck either.
I've also tried to mount it, in linux, and haven't had any luck either. I think the device is problematic, possibly due to the size, and the file system. However, if someone can figure out why the darned thing is so damned fickle, i'd appreciate it. In the mean time, i'll keep plugging it in, and unplugging it, until it decides to come off my data...
Loading problems.
Repair Service
Find Keyboard and Mice Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
