When I turn on the computer, windows starts up but it stops at the user name and password and has a message that says it could not log me in and to make sure my name and password are correct, but it won't let me click on the actual box to change it and I have to click ok and it just takes me to the desktop. How do I fix that?
If this is your error.
Unable to change the password for Microsoft Networking because of
the following error. Incorrect password. The windows password you
typed is incorrect.
This is your solution.
To work around this problem, disable password caching.
Explains the error more fully
http://support.microsoft.com/kb/198301
Gives help on disabling password caching
http://activewin.com/tips/reg/security_4.shtml
If your Windows PC has is equipped with an Ethernet port, you can
connect your PC and Macintosh using an Ethernet cable. By doing this,
you are creating a small local network, consisting of just the two
computers. Set up your Windows PC by turning on File Sharing. Refer to
the instructions that came with your Windows PC if you're not sure how
to do this.
To locate and connect to the Windows
computer, you can use the sidebar in a Finder window. You need to know
the workgroup name for the computer and the network name (called the
"computer name") for the computer. To connect to the computer, you also
need a user name and password and the name of the shared folder you want
to access. If you don't have this information, contact the person who
owns the computer or your network administrator.
If you cannot locate the Windows
computer in the Network browser, you may be able to connect to it using
the Connect To Server dialog in the Finder.
Make sure the Internet Connection
Firewall is turned off, or if it's on make sure TCP port 445 is open to
allow sharing connections.
To connect you Mac and Windows computers:
In the Finder, choose Go > "Connect to Server."
Type the network address for the computer in the Server Address text box using one of these formats:
smb://DNSname/sharename
smb://IPaddress/sharename
Follow the onscreen instructions to type the workgroup name and a user
name and password, and choose the shared folder you want to access.
I tried that, it didn't work. I have windows xp
It is not my user accounts that aren't working. It is before I get to that point, when windows is starting.
