When trying to restore my windows backups to my pc I get an error message..WINDOWS BACKUP UTILITY HAS ENCOUNTERED A PROBLEM AND NEEDS TO CLOSE.WE ARE SORRY FOR YOUR INCONVENIENCE. How can i fix this problem.THANKS
1st possible solution: Check your hard drive(s) and partitions for errors. You can do this by going to My Computer > right click on a drive > Properties > 'Tools' tab > Check Disk or Check Now
2nd possible solution: You may have backed up your files from an NTFS system and are trying to restore to a FAT32 system. If so, convert your computer to NTFS by right clicking on 'My Computer' > Manage > Storage > Disk Management> Right click on your primary drive > and select convert to NTFS.
Testimonial: "THANK YOU SO MUCH..i NEVER WOULD HAVE THOUGHT TO CHECK FOR THAT..Never had this problem before"
You can use the professional software to recover the corrupt or damaged BKF file. The software is a well known and reliable tool which helps in the effortless recovery process. And also, it offers some amazing features which help in simplifying the recovery process.
For more info, visit - https://www.data-recovery-solutions.com/bkf-recovery.php
BKF Recovery Utility is an advanced and sophisticated application designed to repair corrupt BKF files and restore back the data within. The updated version comes with some additional features in order to add efficiency in recovery of inaccessible or lost BKF data.
Stellar Phoenix BKF Recovery application which helps users repair corrupt or damaged BKF files and restore the information stored in it with accuracy. The software is embedded with other advanced features to help it perform more accurate and efficient recovery of inaccessible of damaged BKF files.
My friend
Try to use RecoveryFix for BKF Repair software it will fix the error and repair your windows backup files easily. To download its trial version visit http://www.bkfrestore.org/
SOURCE: windows explorer issues
uninstall PowerDesk or My PowerDesk. Some malware camouflage themselves as PDShExt.dll, particularly if they are located in c:\windows or c:\windows\system32 folder. Thus check the PDShExt.dll process on your pc whether it is a pest or the real deal. If neither program list above is installed, download http://www.neuber.com/taskmanager/index.html?ref=file.net as run the program.
SOURCE: GENERIC HOST PROCESS FOR WIN32 SERVICES HAS ENCOUNTERED A PROBLEM
generice host process win32, dilog box,then internet is not working.
SOURCE: Why am I getting error message for Microsoft Feeds
This is a problem with Microsoft's RSS Feed Reader. As most people use a different Reader (or don't use RSS at all) this can be disabled. Please follow the instructions below to disable it.
Open Internet Explorer.
Click Tools>>then Internet Options.
Click on the Content tab.
At the bottom, under the Feeds section, click Settings.
Uncheck all boxes and click OK.
Click OK to close the window.
Close Internet Explorer and reopen.
SOURCE: Microsoft Feeds Synchronization has encountered a
This is due to lost network connectivity or slow internet connection.
SOURCE: msftstp.exe has encountered a problem
msftstp.exe is a malware program. Make sure you scan using a good malware eliminator (malwarebytes is a very good free one)
So bottom line, you don't want msftstp.exe to be running and you need to kill it.
Iām happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
