I'm showing standard door jamb switches on each door, so there should be one on each door post or where the hinges are.
Keep in mind the dimmer switch for the dash lights could be turned on.
Thank you for getting back to me. I have looked at the door jams and they don't have the usual buttons that move in and out when you open and shut the doors. The manual says it has eys that may nneed cleaned and the keyless entry eyemay need cleaned too. Of course it doesn't tell you where the eyes are located. And I will check the dimmere switch too. Thank you again.
Thank you> I will check the switch, and I have looked at the door jam. The manual says there is an eye in the doors and it also works with the keyless entry, to look and see if they were dirty. But of course it doesn't tell you where any of those things are located. Thank you for helping.
If they don't have the standard switches, the sensors would be inside the door latches.
