thanks jyackle5 for help. this information is really help full for me. . i was also searching for this. i want to know some manual information about my rc flyg
G o back to your manual. I had this problem also. The procedure must be followed properly. First, make certain your throttle is in the off/down position. Second, turn on transmitter. Third connect battery. Once you place the battery in the enclosure and lock the cover you should be working properly. Last but not least, when finished flying, remove the battery BEFORE powering off your transmitter. You must follow these steps. You can NOT leave the battery in the plane when not in use.
Hi 2 stroke engines are very simple. If there's fuel (under pressure) and a spark it will run. Check the glow plug by trying to start it with glow plug removed but still connected and touching the engine body. If the little center wire glows bright red, then it's OK. Only do this for a second or so. If the plug is OK then it has to be a fuel problem. Traxxas has a long history of cracked gas tanks. Good luck
<a href="http://lightake.com/products.do/category.Wholesale_RC_Aeroplanes_Aircrafts-424">buy RC Airplanes</a> manual task process news being really wonderful. We are access that many useful information collection from here!
