Question about Logitech G25 Wheel And Pedals Set
G25 Wheel No Longer Responsive
OK. I've had the G25 for about 4 months, use it frequently and I'm as gentle as possible with it. It has never seen any abuse or drops. Just today, I noticed that for the first time ever, the whell doesn't calibrate itself when I turn on my computer. So, I go through all the settings, etc. check all of the cables and wires, etc., etc. ALL of the buttons and pedals are fully responsive; the wheel still has no functionality. I can turn it the full 900 degrees, but it turns freely, i.e. it does not center or provide input in my games or in the control panel. Now, I removed the wheel from the desk to check connections, etc. and I noticed that the power wire does have a severe crimp in it; apparently I didn't have the wire fully out of the way when clamping it down. However, it has been secured to my desk for some time. Why all of a sudden does the wheel not work? Like I said, all of the buttons, etc. are fully functional. It's only the wheel that doesn't do anything. Please help! I'm a racing sim junkie and need my driving fix!
  • Anonymous May 01, 2009
    mine stopped working and i have a crimp in the cord too
I have this problem and i emailed logitech, they told me to send the wheel back to the dealer for a replacement :(
Posted on Sep 19, 2007
  • simrob72 Feb 22, 2011
    You have probably answered your own question, it's likely the cable has been damaged. It could have been partially cut when it first got clamped and left very little wire to carry the power. It may have burnt out over time if it was transmitting all the power over just a few strands of wire. Try to borrow a power supply and see if that fixes your problem. It really does sound like your wheel is not getting any mains power. The electronics are powered via the usb connection but the motors are powered directly from the mains via the adapter.
    If it is the power cable you can get a new power supply or fix the original cable. Just cut out the crimped section and strip back the wires and rejoin them.
    While other logitech wheels have a similar power pack, the G25 has dual motors and uses a higher capacity power supply than all the other force feedback devices. It would be ok to use something from another model just for testing but don't continuously use it with anything other than another G25 power pack or something that has similar performance specifications.
Getting the needle into its hole without the automatic threader. I want to manually insert it.
Hold something white behind the needle and the needle hole is more clearly seen for manual threading.
Oct 29, 2017 | Sewing Machines
What is substance abuse
if you don't know what that is then perhaps you need ask momma , or a cop
Feb 27, 2017 | Cars & Trucks
My singer touch and sew is stuck. I can get it to go up and down twice and then the whole thing sticks and i have to turn the wheel with great difficulty
If I remember correctly, the Touch n Sew is an older mechanical machine. If so, most likely it has seized because the old oil has solidified and "glued" the moving parts together.
Pick up some liquid Tri-Flow Synthetic Lube (hardware store or bike shop). Open the top, side, and bottom of the machine. Gently wiggle the handwheel and apply 1-2 drops each place where metal parts rub metal parts. Do NOT oil belts, synthetic, or plastic parts and do not over-oil! Then apply heated air from a handheld hairdryer directed into the internal mechanisms of the machine. Alternate oil and air, and hopefully after several treatments, it will move freely again.
Remember, like your automobile, mechanical machines need frequent oiling and cleaning. If using sewing machine oil, be sure it is Fresh, Good Quality sewing machine oil. If the machine is used frequently, oil every 40 hours of use. If not frequently used, oil every six months (even if in storage).
Oct 07, 2016 | Singer Sewing Machines
Can't transfer calls
Call Transfer is a Class Of Service controlled function. If you can't transfer it's because your phone is in a class of service (or possibly Class Of Restriction) that disallows it. Note that transferring an incoming call to an outgoing line is frequently barred on some corporate phone systems to prevent toll fraud or abuse. Check with your phone system support person.
Dec 31, 2013 | Mitel Superset 4025 Corded Phone...
Dropped my Nikon D50 and now it shows there is no SD card in it and the battery indicator is flashing. Nothing appears on the LCD - including the menu. I've taken the SD card out and the battery and...
Contact Nikon tech support at to see what they recommend. I don't think the warranty covers abuse such as dropping the camera so you may be in for an expensive repair. However, he Nikon techs may be able to suggest something that might help you avoid that expense.
Mar 01, 2013 | Nikon D50 Digital Camera with 18-55mm Lens
I accidentally spilled nail polish remover on my macbook. it works fine now but i've noticed the fan runs more frequently now. is this normal?
it's possible you got some inside your mac. When it heats up, can you smell the remover? It might be that it dried inside and is being reheated every time you use the mac.
Jun 03, 2012 | Apple MacBook Mac Notebook
I have a 1990 harley fxr and when you start the engine oil starts leaking out of the crankcase breather what would cause this
This is a common problem with the older bikes. The reason is the position of the oil tank and the type of oil pump the engine is equipped with. With the tank being higher than the engine, oil will seep past the check ball in the oil pump and into the engine. When you fire the engine up, the oil pump cannot pump the excess oil back into the tank quickly enough and some gets blown out of the crankcase vent. If you allow the bike to sit for extended periods of time, this problem is worse. It's commonly called "oil sumping" around here. When you hear an old Shovelhead rider talking about his bike "puking", that's what he's talking about. I've seen those bikes puke nearly a quart of oil after sitting a few months. I've seen Ironhead Sportsters completely drain the oil tank into the engine. This is normal to a degree but if it gets too bad, you can "reseat" the check ball by removing the plug above the check ball on the oil pump and use a small hammer and punch to gently tap the ball into the seat in the pump. Then, remove the old ball and drop in a new one.
Good Luck
Jul 26, 2011 | Harley Davidson FXR Super Glide...
Bush tv frequently turning itself off
make sure you have not accidentaly scheduled a power off and on if yes torn off/disable them if not check that your power cable is secure
Dec 21, 2009 | Televison & Video
It depends on the amount of abuse and the attention to maintance the bike has received in the past. Clutches can last 15+ years or can be destroyed in a few months of hard (abusive) use.
In this case, you might investigate simply changing the oil. Fresh oil sometimes makes a huge difference - especially with a wet clutch. If the oil has been changed regularly and recently, it's possible the clutch is in need of replacement or possibly a simple adjustment. With the lever all the way released, you should have a small amount of free-play in the lever before resistance is felt. 10MM at the end of the lever, or about 1-2MM at the cable end of free-play is desired.
If this change happened suddenly it's possible that something has failed internally. If so, I do not advise that the bike be run until it is serviced.
Oct 16, 2009 | 2004 Honda VT 600 CD Shadow
Memory Card Error
Two suggestions:
1. Try gently blowing clean air into the memory card slot. It's possible a bit of lint or dirt is on the contacts and needs to be removed. A can of compressed air will work for this.
2. (More advanced) If possible use a q-tip to gently rub the contacts for the memory card inside the camera. Again, you're trying to clean the contacts.
If neither works you'll have to consider bringing or sending your camera in for service. It's possible that it needs to be opened up for service and I don't recommend that you do that yourself.
Dec 19, 2007 | Canon PowerShot A630 Digital Camera
Logitech G25 Wheel And Pedals Set Logo
653 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
