Question about Motorola Mobility RAZR V3c Cellular Phone
Number 9 key not working and left, right , up and down keys
I have a motorola phone, looks like the RAZAR exept its not 3G takes the BR5O battery...help!! it only lets me text..the fact that i cant use the direction keys disables me from using phone book, music etc
  • 29 Answers
Has this phone been dropped? check your local service center if you have a physical damage on the phone.
Posted on Sep 30, 2007
SOURCE:
My Up, Right, 9 and Left key dont work .. how do I fix it?
The metal parts of your keypad may have corroded. Have your keypad replaced by an authorized service center. or you may try this temporary solution.. just keep on pressing and pressing the keys until it works.It may take a while to correct the problem.
Mar 09, 2011 | Motorola Mobility ROKR E8 Cellular Phone
Motorola Razar
That means the your flash cable has damaged. You have to call Motorola and repair it. Some time ago I have the same problem with my D&G phone
Aug 31, 2009 | Motorola Mobility RAZR V3
Keys not working
dont worry.its only the key pard problem.you need to replace the key pad and dont forget to ask the repirer to clean the circut board.avoid hard use of key pad.take care
Aug 21, 2009 | Motorola Mobility W230 Phone US with...
The keypad 3, 6 and 9 of my sonyericcson k750i are not functioning....
If you feel confident and competent enough, try taking your phone apart and giving the internals a good clean, take the white keypad PCB out and clean both it's contacts and the contacts on the phone's mainboard, and clear out any dust. Put the phone back together and see if that's solved the problem. It could also simply be that the keypad connector has worked loose
Key Pressed : Key presses phone appears to see
3 : 3 then left soft key
6 : 6 then right soft key
9 : 9 then back
c : c then #
left soft key : 3 then left soft key
right soft key : 6 then right soft key
(All the other keys worked correctly)
As I didn’t know what was causing this I attempted to move all data stored on the phone to the memorystick so I could master reset and possibly reflash, although after this I returned to the homescreen to find all keys had started functioning correctly again,
9 : 9 then back
c : c then #
Jun 25, 2009 | Sony Ericsson K750i Cellular Phone
Screen black
pls change the ribbon and charger
Apr 09, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Some keys are not working-Motorola Razar V3i
motorola razar v3i, this mobile which sd max support? please tell me urgent.please..........
Jan 30, 2009 | Motorola Mobility RAZR V3i Cellular Phone
To access messages says enter password
without a password,you have to call the phone company
Nov 13, 2008 | Motorola Mobility RAZR V3m Cellular Phone
How to send picture msg
Here's how send a picture in a message.
1. Press the Center Select Key
2. Press the Navigation Key to scroll to Messaging, and press the Center Select Key
3. Press the Navigation Key and scroll down to Create Message, and press the Center Select Key
4. Press the Navigation Key and scroll down to New MMS Message, and press the Center Select Key
5. Press the keypad to enter desired text
6. Press Options, by pressing the left soft key
7. Highlight Insert, and press the Center Select Key
8. Highlight Picture, and press the Center Select Key
9. Press the Navigation Key and scroll up or down to the desired picture
10. Press Insert, by pressing the left soft key
11. Press Send To, by pressing the right soft key
12. Press the Navigation Key, and scroll down to desired contact, and Press the Center Select Key
13. Press Send, by pressing the right soft key
You can find this, and other helpful stuff at
this page on the Motorola Support site
Don't forget to rate this solution once you've tried it !
Apr 17, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Razar all keys lock up occcasionally , sometimes taking the battery out then restart fix's it now its locked up all the time The only key that works is the power off and on
Did you drop your phone on the ground or in water? Because if you did it might of damaged the circuitry and you're going to have to get a new phone.
Feb 24, 2008 | Motorola Mobility RAZR V3
Left, right, up and down direction keys and number 9 key not working
if you are using the MMS or Internet on the Phone, check your service provider if the support these features on your phone. however, try first reset the phone to its original manufacturer setting. Go to
Aug 26, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility RAZR V3c Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
