Incorrect language appears on the display
If the "Before you troubleshoot" checklist does not solve the problem, then try one or more of the following:
CHANGE THE LANGUAGE USING THE PRINTER MENUS
1 From the printer control panel, press .
2 Press the arrow buttons to scroll to Defaults, and then press .
3 Press the arrow buttons to scroll to Set Defaults, and then press .
4 Press the arrow buttons to scroll to Use Factory, and then press .
5 Complete the initial printer setup.
CHANGE THE LANGUAGE USING A BUTTON COMBINATION (IF YOU CANNOT READ THE CURRENT LANGUAGE)
1 Turn the printer off.
2 Press and hold down and , and then press to turn the printer on.
The printer resets and starts the initial printer setup.
3 Complete the initial printer setup.
1Press the "Src/Off" button until the Pioneer CD player turns off.
Press and hold the "Src/Off" button again until the clock displays in the unit screen. In some Pioneer units, hold the "Multi-Control" button until "Clock Set" appears in the display.
Press the "F" (Function) button on the front of the CD player. In some units, press the "Multi-Control" button again to enter the setting mode.
Touch the left or right arrow buttons, or "Multi-Control," to select the segment of the time you want to change (e.g., hour or minute).
Tap the "Up" and "Down" arrow keys, or turn the "Multi-Control" button, to scroll through and select a number for that field. For example, if changing the hour to "2," scroll up or down until you get to the two. Use the right arrow to scroll over to the minute segment of the display. Use the "Up" and "Down" arrow keys to select the numbers that make up the appropriate number.
