Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Tray at the back
There is a tray at the back of the fridge that accumulates water that gives off this foul odour, cleaning the tray is difficult as it cannot be removed so I have to lie on the floor take handtowel and keep swapping up the water until it is dry..................Recently we had a hurricane and was away from home, after one week with all the rotten food and meat it was tedious cleaning the tray out............the smell from the fridge is awful after one day. HELP
  • 63 Answers
IS THIS TRAY ON TOP OF THE COMPRESSOR ? IF IT IS THE HEAT FROM THE COMPRESSOR SHOULD EVAPORATE IT... IF IT IS NOT THEN TRY HAVING A DRIAN HEATER INSTALLED IN IT YOU CAN BUY THEM AT ANY APPLIANCES SERVICE PARTS HOUSE THEY USE THEM FOR COMMERICAL UNITS HAVE A SERVICE TECH DO THE JOB
Posted on Aug 30, 2007
During holydays, due to an interruption in the power service, the food of the freezer department defrosted, and now there is bad odour in the fridge. I cleaned it, but the odour did not disappear. What...
Hi and welcome to FixYa I am Kelly. If you are using it and need to keep using it buy about 4 boxes of arm and hammer baking soda and cut the top off. Place 3 in fresh food compartment and one in the freezer. It takes time but it does eventually pull out that odor. However... you need to look under the refrigerator at the water catch basin plastic tray. Often liquids from a defrosted refrigerator drain into the pan down there and dry out. Then everytime the unit auto defrosts (2 - 3 times a day that) bad odor is noticed again because the water produced from defrosting liquifies the material in the plastic tray. You should clean that tray really well and wipe out all of the black goo / gunk. Make sure you look at the very end of the cabinet drain tube also that terminates in that same pan. I have found that using Mr. Muscle mold and mildew cleaner does a really good job of cleaning and removing that foul smell. A trade secret here we use Endust on a dry clean inner cabinet to make them smell good and shine.
Thanks for choosing FixYa.
Kelly
Aug 29, 2010 | Refrigerators
Strong odour coming from non-removable tray under new fridge
do not frustrated .firsly you should look for any THING THAT block the drip tray from geting out. usually it can be pulled out by PUSH ASIDE THE DRIP HOST SOMTIMES BLOCKING THE DRIP TRAY MOVEMENT IN OR OUT.
LATER CLEANED THE DRIP TRAY & REINSERT IT BACK TO ORIGINAL SITE
Sep 24, 2017 | Kenmore 44273 Side by Side Refrigerator
Water in bottom of refrigerator
there should be a tray that guides water from freezer to a drain located in the fridge section normally held with one screw . take it off and unclog drain ( use a vacuum to **** out sludge) clean tray/guide and mount back on. make sure all moisture is cleaned out after drain is cleared.
Jul 07, 2009 | Refrigerators
Water collecting on bottom of 13 year old fridge
All refrigerators create water when their cooling coils shed frost build-up - that water typically collects in a tray under the fridge body through a drainage tube that exits from a collection trough inside the fridge under the coil through the back of the fridge housing.
First check the tray to be sure it is not accumulating food particles which ultimately can produce molds. Clean any water from that tray first, then look for the tube exiting on the back of the fridge see whether there is any moisture at the end of the tube under the fridge and notice whether the tray has had any recent moisture. Chances are the tube is either plugged or similarly any connector through the fridge wall.
Now, be CAREFUL not to puncture the hose or the connector with a sharp instrument however the drain path must be cleared. Try blowing through the drain inside the fridge with a straw, then add a small amount of baking soda into the collection trough, adding a small amount of water to dissolve and allow this to gradually drain out normally. Only detach the outside tube if the problem has not been resolved in this manner. The tube can be replaced easy enough, the connector through the back is another question - see you parts dealer if it has been compromised.
Jul 05, 2009 | GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB...
Water under crispers in my fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 13, 2009 | Refrigerators
Water/condensation in both dairy tray and bottom of fridge
My guess is you have a blocked defrost drain. The water instead of going down its drain goes down the backside of the frig and pools up under the crispers. Blow out the defrost drain. The only other thing to look for is bad door gaskets.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 16, 2008 | Refrigerators
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
Cleaning drip tray.
I have just removed the drip tray from my fridge freezer and it was relatively easy.
Do not remove the compressor unit.
The drip tray is held in place by a metal clasp which is welded to the top of the compressor. The clasp is a flat piece of metal which must physically twisted to align with the key way in the plastic drip tray. I used thin pair of pliers to grip the clasp and twist it clockwise to line up with the tray key way. The tray then has to be carefully manouvred off the compressor so as not to cause damage or spill it foul smelling contents. This I managed to achieve fairly easily.
Clean out and install then twist the clasp to clamp the tray into position. I don't know what would happen if you didnt lock the tray back in position as it does not seem capable of falling off on its own and it would be easier to remove next time.
Hope this makes sense
Mark
Mar 10, 2008 | Refrigerators
Fan blows out a smell from underneath fridge could it be leaking gas.
I have the same problem with the odor. I took the back off and discovered the drip pan was full of stagnant dirty water. This place is bacteria heaven. The problem I have now is that i cant seem to find a way to remove the pan without taking the motor out and everything. Any suggestions?
Roman
Jul 02, 2006 | Whirlpool GD2SHGX Refrigerator
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
97 people viewed this question
Top Admiral Refrigerators Experts
Jose Pino
steyr1
john h
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
