Question about ViewSonic NextVision N3200w 32 in. HDTV-Ready LCD Television
Viewsonic w3250n no sound, no picture, beeping
Hi, I have a Viewsonic w3250n for appoximately 1 month. I do not have the warranty for it because it was a gift. For some reason when I plug it in and turn it on, there is a BEEPING SOUND, is NO SOUND, NO PICTURE. Can some please help me...:(
  • koitime Aug 26, 2007
    Thank you for the reply Benjmur
    There are no other indicators. it only beeps when i turn on the power to the TV. When the TV is off there is no beeing sound, even when the power cord is pluged in.
    Its been sitting around for a long time. and I tried as you suggested before and it no good.
    just beep...beep....beep....and thats it. no video, no sound unless you include the beeping sound...
    any help would be appreciated...
  • koitime Aug 27, 2007
    How do you do a hard reset?
    Brigadier General:
  • 6,966 Answers
Hi, Any other indicators aside from the beeping sound like blinking leds/lights? For the time being try to do a hard reset, unplug the LCD TV from the mains for a couple of hours and thereafter try again with a known good outlet.. If still a no go, post back, Good luck and kind regards.
Posted on Aug 26, 2007
  • Louie  Role
    Louie Role Aug 27, 2007
    Hi again,
    I can understand your frustration "Its been sitting around for a long time. and I tried as you suggested before and it no good." when you tried unplugging it for hours and no positive result, unfortunately this is the only way to full reset the system.
    Other than the hard reset and checking your signal source (cable, DVD) am afraid no other user step you can do. Since it's still a no-go, you would have to seek the services of an on-site qualified repair professional to repair the unit since this involves diagnosis and probably an in-shop work.
SOURCE:
ViewSonic PJD5132 machine turns on but there is no picture. Automatically turns of with a red light on the lamp button after about 2-3 minutes.
Sounds like the lamp is bad. If you take it out, look to see if it is broken or if there is a bubble on the lamp. If either of these is the case, buy a new lamp. If it's not the lamp, it's the igniter and if it's only 3-4 months, it's still under warranty and that should be fixed.
Feb 17, 2015 | ViewSonic Office Equipment & Supplies
Brand new viewsonic vnb130, worked fine for two weeks. Heard whirring noise today and then it boots up, gets to homepage beeps loudly on and off until it switches itself off about 30 seconds later.....
If your laptop is beeping it indicates a motherboard issue that can not be corrected without a technician. Since the laptop is under warranty I would return it with haste for exchange.
Jan 13, 2011 | ViewSonic Computers & Internet
View Sonic Monitor Serial No. QQ2081640466 Model No. VS11826 please let me know warranty of this monitor
Hi u3salkar, What the warranty covers:ViewSonic warrants its products to be free from defects in material and workmanship during the warranty period. If a product proves to be defective in material or workmanship during the warranty period, ViewSonic will, at its sole option, repair or replace the product with a similar product. Replacement Product or parts may include remanufactured or refurbished parts or components. The replacement unit will be covered by the balance of the time remaining on the customer's original limited warranty. ViewSonic provides no warranty for the third-party software included with the product or installed by the customer. Check this link ....http://www.viewsonic.com/support/warranties/limited-warranty/
Hope it may helps:
Regards; VOTIT
Dec 03, 2010 | ViewSonic VA1716w Monitor
LCD model viewSonic vx2235wm 6 months out of warranty, When powered up, the backlight will flash, but then screen is dark. The blue light at the bottom is on and Vista recognizes the monitor. Sometimes, I...
Are you sure about no bad caps? The top of the caps have to be completely flat, and bad caps can also look normal but can have high ESR, you will need meter that can read ESR of the caps.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Post the pictures of the board and caps.
Sep 05, 2010 | ViewSonic VX2235wm LCD Monitor
I want to see my lcd monitor's waranty status from my serial no
Hi
you can call ViewSonic Customer Support: 800-688-6688 in the U.S. and 866-463-4775 in Canada, give them your product serial no and they would be able to give you the status on your product warranty.
In case you want to avail the warranty service they would also give you a RMA (Return Material Authorization number) number.
As mentioned on ViewSonic website "ViewSonic LCD computer display products carry a three (3) year limited warranty for parts, labor and LCD backlight. Optiquest products carry a limited warranty of one (1) year for parts, labor and backlight. In order to receive warranty service, proof of purchase of the ViewSonic product is required."
Hope this helps
Regards
KreativeGeek
Jun 23, 2010 | ViewSonic VA1912w 19" LCD Monitor
Need tip size for viewsonic powere supply
insidecomputer_2070_4186448
Replacement Part Number: 1267-0526
Specs:
  • 40 Watt, 12 Volt AC Adapter
  • 4.8 mm Barrel Connector with Positive inside
  • Condition: New
  • Warranty: 12 Months
  • 100% OEM compatible, Guaranteed to meet or exceed OEM specifications
Compatible Models:
  • Hewlett Packard Jornada 680 Series
  • Hewlett Packard Jornada 720 Series
  • Hewlett Packard Jornada 728 Series
  • HP Jornada 680 Series
  • HP Jornada 720 Series
  • HP Jornada 728 Series
  • Planer LP150-BK
  • Viewsonic VG150
  • Viewsonic VG-150B Model
  • Viewsonic VG151
  • Viewsonic VP140
  • Viewsonic VP150M
Sep 07, 2009 | ViewSonic VG151 15" Flat Panel LCD Monitor
Viewsonic VX724 LCD Monitor
I contacted ViewSonic and they agreed to fix the problem as a warranty repair. Evidentially they're experiencing the same issue on many of these monitors. I had to pay for shipping to their Walnut, CA facility, they'll fix it and pay return shipping. Since it is considered a warranty repair, I think they should've paid for a round trip ticket. I don't want to sound like a cheapskate but it is a warranty repair and the shipping charge was $98.00. Ouch! Cheaper than a new monitor I spose, so I'm thankful for that. So those of you with this problem might consider contacting ViewSonic to see if they will repair this on a recall "like" basis if your warranty is up. If it isn't up yet, by all means send it back to them and make them fix it!
Jul 30, 2008 | ViewSonic VX924 19" LCD Monitor
Viewsonic warranty
I've had several problems with Viewsonic screens, and not only with screens but also with their technical support which would litteraly take monthes to proceed with the replacement of faulty screens.
Two things you should know :
You can find spare power supply cards, it's easy to open the screen and take out the power card so that you can see the reference, usually a card like that costs about 10$, not a big deal for saving the screen
The other thing is that you shouldn't buy Viewsonic screens anymore, there are brands from asia like Hyundai (for workstations) or Samsung for personal use, who have a way better technical support, the best part being that you usually never have to call them :)
Feb 07, 2008 | ViewSonic VA712B 17" Flat Panel LCD...
Viewsonic Projector not displaying RED
Hi there
This could be a problem on the Mainboard - because all the proccessing from your inputs is done on the Mainboard.
Try replacing it , I'm sure you'll have joy then.
Dec 28, 2007 | ViewSonic PJ551 Multimedia Projector
WHERE Can i get a viewsonic remote?
Try visiting the part store the following link, make sure you have the correct serial number. http://www.PartStore.com
Also to buy universal remotes try visiting http://www.ilektroniks.com
Thanks
Nov 21, 2007 | ViewSonic RLC-006 Remote Control
ViewSonic NextVision N3200w 32 in. HDTV-Ready LCD Television Logo
697 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
