Question about M-Audio M AUDIO RADIUM USB KEYBOARD SNDUS70070
M-audio 49e I have an m-audio 49e midi controller. I bought it over six months ago and I can't get it to work. I'm not the most savviest individual when it comes to sound or pc or anything, but where I bought it it worked just fine. I don't know what else to do. I have a pc. I use cakewalk music creator as my host recording program. any ideas?!
  • Anonymous Nov 21, 2007
    tried different drivers does'nt reconize
    Novelist:
    Champion:
  • 382 Answers
Youve gone through the settings to make sure it is sending and your computer is receiving on the same midi channel?
Posted on Oct 23, 2007
Hook it up with a USB cord that goes from your computer, to your keyboard. in the hole that says, wait for it... USB.
Posted on Sep 15, 2007
Problem with the Gemini Sound Products Gemini CTRL-SIX USB/MIDI DJ Controller and Audio Interface It wont be detected by the computer's usb on WIndows 7
In the control panel, sounds and devices, check that the device is in each list under audio, voice, and hardware tabs and that your device is the default device. If NOT in the list, the CORRECT drivers are NOT installed or not properly installed.
Jul 23, 2011 | Gemini Sound Products Gemini CTRL-SIX...
I have just bought a second hand Evolution MK-161 MIDI controller music keyboard on ebay. It works fine when I play it through my computer using the virtual organ software 'Hauptwerk' (which is the prime...
You must use some form of MIDI sound generator module connected to get sound... It is a standalone capable MIDI generator, but NOT generating audio.
Mar 01, 2011 | Music
When I hit a key, it is off by just a millisecond. How can I calibrate my m audio keyboard?
who cares its just a millisecond and its just takes a while for it to load on the computer nobody actually counts the time it takes
Dec 06, 2009 | M-Audio Keystation 49E 49-Key Entry-Level...
Can't get Casio CTK 601 / 611 to function as MIDI Contrller
I'm not at home right now where all my manuals are so I'll try to explain with out. You will have to set it so that the keyboard is the slave device. Try setting it to Omni receive. It has to be able to listen for all midi channels at once. You have to write a sequence on your computer and hook it to your keyboard by using midi out on the computer to midi in on the keyboard in order for you to use the computer as a controller. If you need the keyboard to create the sequences then you have to hook the midi send on the keyboard to the midi in on the computer play/enter your notes into individual tracks in your software then assign channels, voices etc to each track and save the sequence. Then when you hook it up the other way the sequence will play just like an audio recording except the sound w2on't be there. What you have recorded by creating a sequence is a series of midi messages that the keyboard will receive if you have it set properly and hooked up ptroperly which it will translate into sound. This is a minimalist explanation at best. You will have to have a better understanding of not only your keyboard but also your software and midi in general. There are some pretty amazing things you can do with midi. For instance if you have a lighting controller that is midi capable you can i,mbed all the lighting scene changes for your song in order on one track. You can also control your guitar effects pedal to change effects automatically while your playing. Once you get a handle on it you are only limited by your imagination and your budget. Hope this helps in some way.
Jun 01, 2009 | Music
The piano wizard software won't recognize keyboard
you should go to your  utilities --> audio midi setup and make sure your system is recognising your midi device. Play around with your midi settings, see if you can get something going.
Otherwise the problem maybe with the software clashing with Leopard. Double check on the manufactures website that their software is compatible with 10.5.6, or they may have an update for you.
Thirdly you could check if you keyboard is working correctly by opening garage band and making a new software instrument track, press record and see if you get any thing.
Good Luck hope this helps.
Mar 22, 2009 | Wizard Publishing Piano Wizard PREMIER...
M-Audio keystation 49e stopped working
JA user_offline.gif vbmenu_register("postmenu_31136", true); M-Audio Tech Support Join Date: Jun 2008 Location: Irwindale, CA Posts: 5,033 icon1.gif "I asked our repairs department and they said the problem is either the main board or the velocity board. You can order both boards from our repairs department and return the one that is not needed. The main board goes for $20 and the velocity board for $14. 626-610-2529, Mon - Fri, 9am - 5pm Pacific Time."
I just found this in the M-Audio forums. I've just called the number and left a message at M-Audio requesting a callback. I'm really hoping that tech support will have a solution for whatever is causing this malfuntion. . . I'll post here again when the parts come.
Aug 16, 2008 | M-Audio Keystation 49E 49-Key Entry-Level...
M-Audio Keyboard 49e disfunctions after some time
Sounds like it might be a power supply issue. Unless it is mains powered.
Try removing all other USB devised. If that doesn't work its worth try a Mains Powered USB hub.
Feb 26, 2008 | Computers & Internet
Problem with "M-Audio 49e keystation"
Buy a Mac, Then you won't have that problem.
Oct 21, 2007 | M-Audio M AUDIO RADIUM USB KEYBOARD...
Computers & Internet Logo
648 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
