Question about LG WM2487H Front Load Washer
Not enough water
I just bought an LG WM2487H. THe first load ran fine. Water level was up on the door a couple of inches. We had a thrnderstorm that night with the power going off and on several times. Now the washer just puts in enough water to get the clothes wet and not enough to actually wash them. I tried several different cycles & tried unplugging it for a couple of hours. Nothing helped. Any ideas??? I have a large family and can't do without a washer for a week or two waiting for a service tech to look at the brand new machine. Thanks!!!
  • Anonymous Jun 30, 2008
    Funny thing, after a week of having the thing, I have the same problem.
    Only enough water to wet the cloths, but not clean them,
    I am just disgusted with this machine.
  • Anonymous Mar 23, 2014
    not enough water to wet all clothing in washer
  • 625 Answers
The timer motor is what is called a hysteresis synchronous motor. it runs off 120 volts and synchronizes itself with the frequency of 60 cycles which is what your power co is feeding to you. with your power going on and off and on and off, it created spikes on your house circuit which probably burnt out part of the timer motor. replacing just the timer motor should take care of the problem. the whole timer costs a lot of money like around $130. If yours is a solid state timer, there's no motor just a preprogrammed computer for fill, agitate, drain, rinse and spin. I have no idea what a new board costs but try parts select dot com. they have parts for major appliances.
Posted on Aug 26, 2007
STILL Leaks after parts replaced...and now water level sensor issue.
there is a small pipe that runs from the drum buttom to the diafragma sensor water level
(it's a round thing 5" at the highst point in the machin) this item close a sircet and close the water inlet.
please chace for cracks or blocks in this pipe
all rhe best
Dec 17, 2013 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
I have the LG wm2487h*ma front load washer.My washer is filling up with water when not in use. When I wash a load, the water does not go in the washer. Have opened the door thinking the wash cycle is done...
The problem would appear to be the water inlet solenoid valve.
The valve is not operating correctly for some reason allowing water into the machine even when switched off
Sep 02, 2017 | LG WM2487H Front Load Washer
LG wm2487hrm Washer not draining water. tE flashing. I drained water out of front and ran 2nd cycle same issue.
tE is a thermister error. It is a temperature sensor at the bottom front of the washer. tE can also be caused by a heater error. Some models have a seperate thermister, some incorporate it with the heater. It is very difficult to replace without taking the front off the machine.
Jan 25, 2011 | LG WM2487H Front Load Washer
Code fe
FE Over Flow Error
Water is overflowing (water level frequency is over 213).
If FE is displayed, the drain pump will operate to drain the water automatically.
(may be too much suds ...)
WM2277HW Service Manual HERE...
Locate your service manual behind the kick panel of the machine.
FE means overflow condition.
Before replacing the fill valve sand or trash may have gotten into the tube going from tub to water level switch.
So find that hose and blow it out. Remove the standing water and retry.
Thanks for using FixYa!
Jan 12, 2011 | LG WM2487H Front Load Washer
Display says error
I have give the same solution in other post, here it is :
usually problem with semi auto washing machine is on the sensors , exactly in the water level sensor, please check the hose that connected to water level sensor, make sure no dirt blocking or clogging the hose. also you can clean the tube under the pulsator, usually there is many dirt blocking the hose line.
the problem is in the hose leading to the water level sensor, if there is no dirt and looks normal, water level sensor must be replaced
Jul 24, 2010 | LG WM2487H Front Load Washer
Won't finish washing displays IE
Check your water frequency level it is below 26 you will get the inlet error. Here is something you can try:
When you press the "SPIN SPEED" button and "SOIL LEVEL" button the water level frequency should be above 246. If it is below that number remove the top; find the small tube going to the main control on the backside and blow it out. Get rid of the sediment and reconnect tightly. Pump out water and retry.
Jun 16, 2010 | LG WM2487H Front Load Washer
My LG WM2487H has water in the detergent cup at the end of the wash. It has happened twice now.
This is normal.
All LG washers use a siphon system to dispense soap, bleach and fabric softner.
Some times water will remain in the cups depending on the cycle used.
Jan 20, 2010 | LG WM2487H Front Load Washer
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
Can you adjust the water level on the LG Tromm WM1814CW? The water level when washing and rinsing is so low that the clothes are barely wet when the washer has finished.
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Mar 29, 2009 | LG WM1814CW Front Load Washer
LG Tromm WM2277HW Water level to low
this is normal the pic are all photo shop water you clothes are clean right?
Feb 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM2487H Front Load Washer Logo
239 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
