Question about Whirlpool LGQ9858P Gas Dryer
Whirlpool clean touch dryer
Not sure that is the model. It is at least 7 or 8 years old. I order part #341241. The belt broke and after I replace the belt by mistake when I was cleaning out the lint at the bottom of the dryer I knock a white wire loose. I see know where to hook the wire back up to. their is no heat coming from the dryer now. I have worked with fixing computers for years Just can't find the connection. can you please help. It would be greatly appreciated. thank you
  • 63 Answers
Sounds like the wire that goes to the flame sensor switch if it is gas there is a black wire and a white wire that goes to it its on the left side of the gas valve on the flame housing tube / pipe
Posted on Aug 29, 2007
What belt comes with whirlpool kit # 4392067?
If you have a whirlpool dryer with the lint filter that comes out of the top cover you would need belt #341241, Whirlpool Dryer Drive Belt 341241
That kit looks like a front-lint package...probably contains a #66157 belt. Whirlpool Dryer Drive Belt 661570V
Jul 06, 2016 | Whirlpool Dryers
How to replace an Dryer Drum Belt ?
check youtube for a lot of vids on this subject
Feb 14, 2018 | Maytag Performa PAV2200
Dryer belt keeps breaking
Did you check the idler pulley to be sure it wasn't damaged in some way, like a break in the plastic wheel or metal causing it to cut away at the belt until it breaks
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 25, 2012 | Kenmore Dryers
Part number 8066065 kenmore heavy duty super capacity dryer electric belt for dryer tub
Hi mousessugar2...
Go to the following webpage and order your belt...it has changed numbers
It is no longer part number 8066065...It is now a Part number 341241.
Please take time to rate me thumbs up.
http://www.appliancecarestore.net/replacement-for-kenmore-amp-whirlpool-dryer-belt-341241.html
Sep 24, 2011 | Kenmore 63942 Dryer
The dryer belt broke. I bought what I thought was the replacement belt but it is too large to fit the drum and tensioner pulley. Upon inspecting the motor, the shaft has a grooved portion around which...
You did not provide the model of your kenmore dryer so i can't provide the correct part # HOWEVER
you can go here:
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
and enter your model number and get exploded views of your machine, part numbers and the ability to order them directly from Sears
Feb 05, 2011 | Kenmore Dryers
Need model number or part number for whilpool dryer
The model number for your dryer is usually located on a plate or sticker inside the door on the body of the dryer hidden by the closed door.
The most common (but not the only) belt number for Whirlpool dryers is 341241 and the idler arm for that common dryer has tabs that fit into the floor beneath the motor drive pulley. Take a loop of the belt with ribs inside the loop and pass it through the opening below the roller and loop it around the motor pulley. If it's the most common unit the end result should look like the image below for Whirlpool:
Belt Configuration
Good Luck
Sep 07, 2009 | Whirlpool Dryers
Whirlpool Dryer wont spin
If it heats but doesnt spin, most likely the belt. May not be broke though. May have fallen off. Let me know if you need more help.
Dec 16, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool dryer at least 10 yrs.old
belt broke remove 2 screws under lint screen release clips under edge of top on each corner by pressing in with putty knife..lift top remove screws upper corners each side top ..disconnect door switch connector lift front off install 341241 belt per diagram on bag
Jul 30, 2008 | Dryers
Kenmore dryer
The belt you will need for that unit is part # 341241. These belts will fit almost all Whirlpool and Kenmore models except for the DOTT (Dryer Of Tomorrow, Today) dryers. A DOTT dryer is a Kenmore model only, and has a front kick plate and the lint filter in the door.
Jan 27, 2008 | Dryers
Whirlpool LGQ9858P Gas Dryer Logo
1,271 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
