Question about Danby DAC8003D Air Conditioner
Not blowing cold air
Blows fine fan is fine but put on AC the air isn't very cold
SOURCE:
  • 7 Answers
SOURCE: EverStar MPM2-10CR-BB6. Comp. only runs for about
check the start gear for the comp.
Posted on Jun 27, 2009
heatman101
  • 43501 Answers
SOURCE: danby ac is not functioning properly cool air, not cold
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
heatman101
  • 43501 Answers
SOURCE: Danby DB98-26786A window air conditioner will
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Posted on Jul 24, 2011
heatman101
  • 43501 Answers
SOURCE: Just bought a 2 yr. old Danby DAC5209M window a/c
heatman101
  • 4736 Answers
SOURCE: Our Danby model dpac 11006
The intermittent sound you're hearing is probably the compressor trying to start. This could be caused by a bad circuit or the compressor motor is seized If the latter is the case, it's time to start shopping for a new AC. As the cost to repair would be almost as much as a new unit depending on the age of your unit. However, compressors usually have a 5 year limited warranty. So check you Owners Manual for details. It may still be in warranty.
Hope this helped you and thanks for choosing FixYa.
Posted on Aug 11, 2011
Why car isn't blowing cool air except while driving fast?
Are you saying the air coming out of the vents is not cold unless you are moving ? Or there is no air unless you are moving ?
And are you sure the radiator fan is running with the ac on ? Can you feel air being pulled thru the condenser ? What are the gauge readings with the ac on and the engine at idle ?
May 18, 2013 | 2003 Mitsubishi Eclipse Coupe
My heat isn't working..the fan blows cold air
Depending on the year make and model, it could be a blend door problem if the heater hoses are hot.
Oct 08, 2012 | Cars & Trucks
My GE model GSH25JFTCBB side by side is not cooling in the fridge side. Freezer seems to be doing fine. What could be wrong
you could have a defrost problem,a bad damper,bad computer board.first thing,open the freezer door,do you hear the fan blowing in there?you should,if not the evap fan motor is bad,if it's blowing touch the back inside wall of the freezer to see if any frost or like snow is on it,from the bottom up in the freezer remove the second bin of food and touch the back inside wall with your hand,if it has frost or snow you have a defrost problem,bad defrost thermostat,heater,sensor or board,if there isn't anything on the wall then you have a bad damper,all that happens is the evaporator coil in the freezer gets cold,then the evaporator fan in the freezer blows the cold air over into the fridge section,you have a damper in your machine that opens and closes when it's cold enough or when it needs to get colder,the door on the damper isn't opening to let the cold air in when it calls for cold air.if you can write back and let me know what you find and hopefully we can get it fixed.
Sep 15, 2012 | GE Refrigerators
Blows cold when first started and then blowes warm
I would replace the AC compressor cycling switch it may be sticking have seen it a number of times. The switch is located in the receiver dryer on the passenger side of the engine compartment. See picture below.
If this isn't the problem the AC compressor relay may also cause this, flip a coin.
Sep 13, 2012 | 1999 Ford Taurus
'97 Jeep Grand Cherokee AC "Works and Stops"
Make sure your fan clutch is working. No fan, no cooling of the condenser, no heat dissipation, no cold air. Start the truck and make sure you feel air movement, a lot.
Aug 11, 2012 | Jeep Grand Cherokee Cars & Trucks
Car blows warm air when idling
It sounds like your AC unit could be overheating or even damaged.
AC units have a sensor that will turn them off automatically to prevent damage from overheating. If there is an insufficient amount of air flow, the unit will heat up, and then eventually turn off.
When the car is moving, more air is forced over the unit, likely keeping it cool enough to run, however, when the car come to a stop, it loses that air flow, and quickly heats up. Thus, the AC would work while the vehicle is in motion, and overheat and stop when the car is stopped and idling.
However, the AC unit could be completely blown. The cold air while moving could be just a case of air being forced into the car. Think of a house fan, the fast the wind blows on you, the cooler it gets.... Thus, it could be an illusion that the AC is working when car is in motion, when it really isn't.
Hope this helps.
Jun 09, 2012 | 2004 Lincoln LS
Where's the fuse for the AC on 98 Olds 88?
So what does the fuse that blows, protect?
You need a wiring diagram & start to test
the components most likely to cause a high
current draw & blown fuse.
Don't keep replacing it.
You know the fan control circuit works, but the
compressor doesn't stay on. Did you monitor
the compressor as the fuse blew?
May have a module for compressor & fan
If so one side failed
The compressor clutch could be bad
May 24, 2012 | 1998 Oldsmobile Eighty Eight
Only half of the freezer and half of the fridge are working
heat rises and cold stays down on the lower shelves,if the evap fan motor isn't blowing this will happen,next time send the brand name and model number off of the machine,open the freezer door,if you don't hear the fan blowing you have a bad evap fan motor,all it does is the freezer gets cold,the fan blows the cold air from the freezer to the fridge section,also if the fan isn't working when you remove the back inside wall of the freezer if there's any ice melt it out with a hair dryer,unplug the machine before you start working on it,call your parts store,give them the model number and they will sell you the parts you need.
Oct 10, 2011 | Refrigerators
When idling, a/c blows hot. New compressor installed. But whwn driving it blows cold
Check the fan. Some systems have a separate fan for the AC when running. If it isn't running when up on temp, check fuses, and the fan. If good, check sensor and relay.
--W/D--
May 31, 2011 | Air Tools & Compressors
Danby DAC8003D Air Conditioner Logo
Top Danby Heating & Cooling Experts
Dennis Boxerman
mintvl
Level 1 Expert
Bill Long
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
