Question about HP Pavilion ze4220 Notebook
Hp pavilion ze 4200
All i want to try is reset the computer back to manufacturers setting how do go about it what do i have to do to get it set back to the begining
    Brigadier General:
  • 6,966 Answers
Hi, Your post may refer to three (3) settings: 1) BIOS for the laptop/hardware itself or the 2) operating system or 3) password. BIOS - Upon restart, when the logo screen is displayed, press F2 to enter BIOS Setup. OS - to really get back to the beginning: 1. Go to System restore and click on the first/earliest date of restore point. This would perhaps be the earliest backup of your system and everything will revert to as to how it was then; or 2. Reformat, clean/fresh install of Windows. Now if you are referring to forgotten BIOS or entry password, you have to bring it to HP service with proof of ownership/purchase and other documentations. Good luck and kind regards.
Posted on Aug 26, 2007
SOURCE:
How to reset my computer HP Pavilion back to factory settings(?)
As long as you havn't deleted the 'hidden partition oir 'formatted your hard disk. then you will be able to 'reset to factory'
The method used to restore software and drivers depends on the operating system that was originally installed on your notebook PC.
There are several pages at HP for your machine. I think this one may be what you want.
You use the F11 key to start recoverry
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01612373&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=1817074
Sep 14, 2014 | Altec Lansing 417089-001 - HP Pavilion...
How to unlock my bios password?
Removing the CMOS battery like the one shown in the picture to the right will cause the system to loose all CMOS settings including the password. To do this locate and remove the CMOS battery on themotherboard for at least five-minutes. After this has been done put the battery back into the computer and turn it back on.
Jump the CMOS solder beads
Older computers and especially older laptops don't have jumpers or dipswitches and require the user to jump a pair of solder beads on a circuit board. The identification and location of these solder beads can vary and if not available in computer documentation is only obtainable through the computer manufacturer.
If you've identified the solder beads they can be jumped by placing a flat-head screwdriver over the two beads and leaving it on those beads while turning on the computer. Once the computer has booted turn off the computer and then remove the screwdriver.
Jan 10, 2011 | HP Compaq Presario 2500 HP Pavilion ZE...
Bios will not save my settings and can not locate my hard drive comes up not found.i have a hp pavillion ze 5170
Ya need to replace the cmos battery inside your notebook,
If this is too much of a project, take it to a computer shop that YOU trust
Jul 24, 2010 | HP Pavilion ze5170 Notebook
Printer will only print one copy when when multiple copy number is entered. HP Laserjet 4200 printer
The best way I have found to remedy this type of issue is to reset the printer to factory settings. Push the check mark button (green) and scroll down to the resets and restore to factory settings. This will reset everything and you can start over. Also on the computer you are printing from there are default settings under the printing preferences that should be set to default printer settings. You can try one or the other but I usually do both because it saves time in the long run.
Mar 10, 2010 | HP LaserJet 4200 Printer
Need f key instructions to reset hp pavilion ZE
No key needed, just boot from the recovery cd that came with the laptop when you bought it and follow the instructions on the screen.
Oct 28, 2009 | HP Computers & Internet
Nx9010 power on problem
choose load default settings then save and exit.
then we;ll go from there.
keep me informed
Mar 08, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
I am unable to set up wireless.
What model router do you have? Are any other computers connected to this router? Can you see the SSID for your router when you attempt to connect?
Dec 20, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
Does this Hp Pavilion zv5000 Laptop Batteries Fits for Hp Pavilion ze Series Laptop
hp pavilion zv5000 battery Compatible with Code:
  • Compaq 346970-001
  • Compaq Hstnn-db02
  • Compaq Hstnn-ub02
  • Compaq pp2100
  • Compaq pp2200
  • Hp 346970-001
  • Hp Compaq Hstnn-ib04
  • Hp dp390a
  • Hp dp399a
  • Hp Hstnn-db02
  • Hp Hstnn-ub02
  • so it is campatible with it~~
  • Nov 21, 2007 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
    CTX Optoma EzPro 580
    Hi, Optoma USA recommend that you set the PC resolution to SVGA (800 x 600) or XGA (1024 x 768). Your HP Pavilion ze 4900 default resolution is S = SXGA (1400 × 1050) or X = XGA (1024 × 768). I would assume that your cable(s) are properly mated/attached from the laptop to the projector. If on pressing TV Now! One-Touch button with a TV icon at the top of your keyboard to switch the display to the TV-Out mode, there is no picture projected, you can try to manually lower the screen resolution of your PC. Try lowering it to the 800 X 600 setting in your Display Properties. Also, you may want to check if the Dual Display Mode is enabled/activated. You can try different resolution setting as long as the projector can handle it. Hopes this works and give you an idea. Should you need more assistance, pls post/comment. Good luck and kind regards.
    Aug 11, 2007 | CTX Optoma EzPro 580 Multimedia Projector
    HP Pavilion ze4220 Notebook Logo
    171 people viewed this question
    Top HP Computers & Internet Experts
    Ekse
    Thomas F. Schneider
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
