Question about Nikon D1H Set Digital Camera
Card Error When I switch on the camera, it says card error. When I use the card in PC using card reader it card is read by the PC. What to do next?
    Problem Solver:
  • 17 Answers
I would first back up all the pictures on the card, and then while you have the memory card in the card reader re-format the card and put it back in the camera. If you are still having problems the electrical contacts on the inside on the camera may be dirty. Use some canned air and blast out anything that may be in there.
Posted on Aug 28, 2007
SOURCE:
My camera says card read error. How do I correct the problem?
Hi, card read error can be a faulty card or a problem with your camera. Only way of checking is if you have another card to try in the camera or if you have a card reader that you can put the card into and connect to your pc and see if that is able to read the card if the card is able to be read by the pc then it looks like a camera problem.
Dec 09, 2015 | Fuji Cameras
Hitachi hbc 161e sd card error
Try formatting the sd card using the camera. You should be able to find in the menus.
May 03, 2014 | Hitachi Cameras
I can take pics & download to pc. I can take movies & watch on camera, can't download. pc reads : error-2002: a bad public movie atom was found in the movie. tried everything, stumpped.
Downloading from a crad reader, such as the pc card port should work. However, if your card is a 4GB or newer SDHC card, and your computer is more than a few years old, its card reader port may not be able to read the SDHC card (these only came out the past few years). In that case, just purchase an inexpensive USB SDHC card reader (should be only a couple dollars on Amazon, see this). You might also need to use recovery software if the card is becoming corrupt (see this). If all the above works, consider using the USB card reader in the future for downloading all your photos and videos. Also consider purchasing a better quality model card reader at a later date, as the one I linked for you is very cheap/low quality, and meant just for you to try to see if that's your problem.
Nov 14, 2011 | GE A830 Digital Camera
My camera is coming up as read error on screen finepix s1850, and cant find my pictures
Error ? Some additional code?
Could be some SD card problem; try to copy and make one backup of your images in the pc, use a SD card reader to this. Next step, re-format your SD card.
Keep us updated.
May 31, 2011 | Cameras
My Sanyo VPC-S880 when turned on, says "Card Error'. What does that mean and how can I rectify that problem? The card is in correctly and because of this "card error" I cannot check the pix that are...
First, ensure that the card has not been locked. There is a small sliding switch on the side of the card that you may have accidentally shifted into the locked position. If so unlock the card and try it in the camera again.
Your next option is to fit the card into a card reader (on you laptop or PC) and see if it is reading any of the data on the card. If it doesn't, and the card is not locked, the card may be defective.
Aug 10, 2010 | Sanyo VPC-S880 Digital Camera
Hi there when i switch the camera on orange is flashing and screen is reading access can't take any pictures
pls take out the card and format in card reader on pc and then use it in camera it seems like typical card file system corruption error
pls rate me well
Aug 11, 2009 | Sony Cameras
Card error
TRY TO FORMAT THE CARD INTO YOUR PC, USING A MEMORY CARD READER.
Aug 16, 2008 | Fuji FinePix Z10fd Digital Camera
Communication error
If your SD memory card contains more than 1,000 images, the camera will display "Communication Error". Use a card reader (if available) to import your images into the computer, or see about having some CD's made at a photofinishing business.
May 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Toshiba Card Error
Try formating the card in the computer. This can be done with windows explorer, just right click on the drive that the card is in, a menu will pop down and click format, then start. Hope this helps.
Aug 26, 2007 | Toshiba Sora PDR-T30 Digital Camera
Nikon D1H Set Digital Camera Logo
128 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
