Question about Bissell 1960-3 QuickSteamer Plus Upright Vacuum
Bissell 1950F Wet Pick Up Vacuum Cleaner
The water from the input tank will not release on to the distribution bar and then on to the carpet. The wet vacuum is operating correctly. It appears the water release valve mechansim is not allowing the valve to lift, thus releasing the tank water. There is slight movement of the valve observable when the trigger is actuated however the lift is not sufficient to release the water. Is there a Bissell Service Centre in Sydney
Dear Schonaldo, Thank you indeed for your reply. I phoned Bissel to locate a service centre close by as I did not have the expertise to do any repairs. The Bissel call centre referred me to their in-house service people who confirmed your finding that the machine is gravity fed, however they also suggested that sometimes there is a problem because of an air lock. Their suggested solution was to fill the tank and depress the trigger a few times and, if this did not work, to hold the trigger down for a period. It took me a day or so to get back to the machine and it could have been that the air lock was dispelled by time, however, when I re-filled the tank and depressed the trigger everything started working again. I wonder also whether I may have put too much cleaner solution into the tank, which may could have further exacerbated an airlock situation. Alternatively, I notice that the air vent at the top of the tank is very small and I have inserted a needle to open it up a little, thereby creating more pressure. Anyway hoorah - everything is working OK.
Posted on Sep 01, 2007
I have the the same problem.. Took machine entirely apart. Inspected the actuator lever, rod, plunger, hose, bar (entire water feed components). Took the tank apart and determined there was a possibility that the curved hose(inside of tank at suction side) could have sucked itself onto the bottom of tank. Modified to prevent this from happening again. Put the machine back together and voila! It worked for a few minutes only if I kept the trigger depressed. I believe the machine was designed for part gravity water feed and part vacuum water feed. Whatever the case, not working too well. Although, I did notice it works better when the clean water tank is full. After inspecting and testing I determined that there is too much vacuum energy being lost to the underside of the brush housing hence not creating enough suction for on demand water supply.
Posted on Aug 31, 2007
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Trigger pin is stuck or something else is wrong. why is it constantly leaking water as soon as I plug it in?
You will need to provide more information as in the model AquaMate you are using as I can't determine which one by your information. You can also call and speak with a tech. at 800-640-2033.
Rainbow Vacuum Cleaner Systems Repair Center
Mar 28, 2014 | Rainbow E series Canister Wet/Dry Vacuum
The bissell carpet cleaner isnt spraying water.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
hjhdg
Jul 10, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
How to release and withdraw water solution to clean carpet.
Problem resolved by contacting a local retailer who provided instructions.
Dec 30, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell carpet cleaner
heatman101
teydh
Nov 30, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
There is no liquid come out on carpet? I just put
piston that sits under mix dial not in place, tanks not seating right,gap in back housing may not let tank meet the plunger pin so that water can release
Oct 29, 2009 | Bissell 7950 ProHeat Upright Wet/Dry...
Carpets soaking wet
turn dial in front on the water tank to floor not tools and thats should do it...go to bissell.com to read and print manual so you can double check everything
Feb 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat 7901 will not **** up water
heatman101
adfa
Nov 11, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 1960-3 QuickSteamer Plus Upright Vacuum Logo
464 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
