Question about Amana ABB1927DE Bottom Freezer Refrigerator
Freezer is working/refrigerator works sometimes
My Amana bottom freezer / top refrigerator has started to work intermittently. The freezer is cold, but no cool air reaches the refrigerator. At first we thought that it needed to be defrosted (the freezer door had been left ajar overnight and a lot of ice had built up in it). Then the fridge started cooling again - but it turns out it's not working 1/2 the time. We had a repair man come, who ordered a new fan motor, but found that the new motor was not working. He thought they sent him a faulty motor, but when he checked it back in his shop, he found the motor worked, but stopped when he reduced the voltage. His diagnosis: we have a short somewhere in the fridge, impossible to find and fix. ?? Can you help?
    Novelist:
  • 87 Answers
No No No. The most likely reason that the evaporator fan is not running is that it probably uses the heater circuit for its neutral feed. I.E. In order for the fan to have 230v/115v it needs a zero voltage brought back through the defrost heater and defrost stat. I know this for a fact because I just did one today and have fallen for this scenario (ie bad fan motor) before. You need to check from ground(earth) to each side of the fan motor (which is easily accessible) and then across the fan motor windings. The chances are that you have zero voltage across the motor. The fan will also not run until the temperature of the evaporator coil has been brought below 0 'C (32'F) and this can take up to 20 mins (again speaking from experience). This is to prevent snow being produced after defrost. I would advise getting the engineer to come back if you have paid him money and do a proper job. Shorts in Amanas can happen but have not come across one yet. Hope this helps.
Posted on Aug 28, 2007
After melting ice (behind freezer rear cover inside freezer) using hair dryer can also wash bottom of fridge with spray of water (rather then vacuum), connect to electricity and let stand for 20 min. works great since. thanks
Posted on Oct 09, 2007
Amana top fridge and bottom freezer both stopped working overnight, cleaned out all the dust and dirt from below
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 19, 2011 | Amana ARB2217CSR Bottom Freezer...
Bottom freezer working great, top not cold
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 16, 2010 | Amana ABB1927DE Bottom Freezer...
Amana ARB1917CB bottom freezer refrigerator, not freezing at all has done this before but have always manage to get it working again top & bottom up as high as it can go, but the top doesnt feel that...
YOUR COMPRESSOR MAY HAVE FAILED. USUALLY ABOUT 800 TO REPAIR. THERE MAYBE A FIVE YEAR FULL WARRANTY ON THAT. OR EVEN A 10 PART ONLY WARRANTY. CHECK MODEL AND SERIAL NUMBER HERE TO SEE. http://servicematters.com/warranty/warranty_main.htm
Apr 23, 2010 | Amana ARB1917CSR Bottom Freezer...
Freezer not freezing nor ice maker
Is the refrigerator still working? Is there any cold air in the freezer? If your compressor stopped working it would cause the refrigerator to be warm also. I had a problem with my amana refrigerator where the freezer wasn't getting cold enough and it was due to a condenser fan running intermittently. i replaced the fan and was back in business. i would check to make sure both your fan and your compressor are operating...
Mar 03, 2010 | Amana ABB1927DE Bottom Freezer...
Have a amana with bottom freezer. Everything
Keep in mind, your fridge 100% depends on the freezer. You have a defrost system problem most likely(see if icying up in the back wall of freezer). And if so, most likely defrost thermostat went bad.
Amana refrigerator repair orange county, ca
Feb 06, 2010 | Refrigerators
Amana ABD2533DEB Bottom Freezer - Fridge not working
Sounds like the circulating fan is either gone or is going bad. This problem is hard to diagnose because sometimes the fan will run but not fast enough to circulate the air through the freezer and refrigerator. I would have your repairman look at this or if you have the know how then you can order the fan and replace it yourself.
Aug 22, 2009 | Amana ABB1927DE Bottom Freezer...
Amana botton freezer buzzing 10 sec, freezer not cooling
CHECK MICRO/ SW WIRES @ FREEZER INSIDE THE CABINET COULD BE LOSE
Aug 19, 2009 | Refrigerators
We have an Amana side by side that is only cold on the bottom in both the freezer and fridge. Also the top shelf of the fridge is hot from the light, which does not seem to go off when the door is shut....
amana runs power to the fan thru the defrost sensor that is mounted on the evaporator coil. these sensors will get moisture inside of them and short out causing intermittent fan operation. replace then sensor and your frig will return to normal. thanks for using FixYa peyton
Feb 17, 2009 | Amana ASD 2624 Side by Side Refrigerator
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
321 people viewed this question
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
