Question about Akai PT4298HD Rear Projection Television
42'' projection tv timer led light blinks
There is no picture or sound when my set is plugged. The only thing that happens is the timer led light blinks 4 or 5 times then shuts off.
I hope that this will help you. My wife and I had the same problem, but we had a warranty from Circuit City. The repair person must have know what the problem was. He put a new circuit board in the TV in less than five minutes. It took him longer to open the TV than to put in the new part. No cost to us, but if we had to pay if would have been in excess of $65.00
Posted on Sep 03, 2007
Mine does the same freaking thing, and Akai Has zero customer support. The manual is utterly useless. I would be happy with 50 fewer features and a reliable TV. Why throw all that stuff in if it means more things can go wrong? I will never buy Akai. I am going to take it to a TV repair shop and see how ridiculous the cost is to fix it.
Posted on Sep 02, 2007
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Sony kp53xbr200
You will need technical experience to fix. First what do you remember happening to set before it went out? Did you have color problems, or alignment problems? There are many things that could be wrong. Open startup resistors, R600-612, IC 601, C667,607,608 etc .
Dec 07, 2007 | Sony KP-53XBR200 53" Rear Projection...
Model WD-57731 LED Timer Light
You have a dm board problem could be the capacitors or you may need to change the entire board.
Sep 16, 2009 | Mitsubishi WD-57731 57" Projection HDTV
Turns on, no picture or sound, light blinks 5X, reboots itself
First thing is to check the lamp. you can easily change this yourself.
May 26, 2009 | Samsung HCM4216W 42" Rear Projection...
Blinking green light under 'Timer' flashes there is no picture
If you have a green blinking LED that runs continuosly, its the widespread problem of failures of capacitors on several circuit boards in the TV. Currently Mits is having authorized service centers remove the chassis and send it them for rebuilding. Its an expensive and time consuming repair.
Feb 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
View timer only lights
TV WILL NOT NOT TURN ON RED VIEW TIMER LIGHT FLASHES AND THEN I CAN'T TURN OFF TV
Mar 29, 2008 | Sharp 61RWP4H 61" Rear Projection...
Mitsubishi VS-50607
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Oct 04, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Sony trinitron tv
If you have sound but no picture it means that your power supply and tuner are working correctly. The number of times the timer LED blinks is the code for the problem with the picture. The computer will stop the picture and blink the timer LED if the vertical circuit stops working, if the picture tube is too weak or if the horizontal sweep has stopped. The set should be serviced by a qualified tech familiar with Sony sets.
Sep 03, 2007 | Sony WEGA KD-34XBR970 34" TV
42" Mitsubishi 52525
You may have bad capacitors in the DM board.
Mar 05, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Akai PT4298HD Rear Projection Television Logo
102 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
