Question about Hitachi 43F300 43" Rear Projection Television
Yellowish color The TV color become yellowish. I know it's not the signal problem because it does so on cable TV or DVD movies. I try to adjust the Video in the setup menu(try brightness, color, tint,...), but it still looks too yellow (brown). I switch the video mode to "cool" (It has 3 options, cool, standard and warm) and the color becomes a little better, but still not normal. Do I need to replace something? Is it worth to fix? Thanks.
    Sergeant:
    Champion:
  • 375 Answers
Turn off the color and see if you have a good grey picture if not your grey scale is off and requires adjustment
Posted on Sep 18, 2007
I have the Insignia Dual 7" Portable DVD Player. Model NS-7DPDVD. I'm noticing a yellowish color on the movies. I adjusted the brightness wheels on both but it's not the brightness it's...
Bring up a menu on the DVD player screen (not a DVD menu, the dvd players settings menu). Is this menu also tinted yellow? It probably is, and you probably have a faulty part internally.
Jun 13, 2011 | Insignia Dual 7" 16:9 Widescreen LCD...
LG CRT TV, picture becomes yellowish
yes it is due to dry solder in vedeo driver section(a board fixed to the pict-tube.).
Jan 22, 2010 | Televison & Video
Yellowish picture everything else is good
That model had lots of problems, it sounds like your loosing blue. Try putting up a color bar chart and see if you have blue. Color bar is availible on most cable systems. ggod luck
Feb 28, 2009 | Samsung PCK520R TV
Hi my monitors screen becomes yellowish.all colour effected y dis
Do you have a CRT monitor?
Have you tried to adjust the color on the monitor?
How is it connected to your computer?
It sound like one of the guns on you monitor died. But there is some testing you should do first.
If it is a CRT monitor and it is connect your computer properly. First thing to do would be to replace the cable and or try a different monitor that you know works.
To confirm try adjusting the color. If that does not work, if it more purplish it is the green gun, if it is orangish it is the Blue gun. That would be cause by a failed gun or driver.
If the gun is gone it is best to get a new one. It will save you money in the long run.
Thank you...
Jan 27, 2009 | Samsung 793S 17" CRT Monitor
CRT monitor becomes yellowish..
When any dust goes inside your monitor .......you will get these things.......... remove it , it will work fine
Jan 12, 2009 | LG Studioworks 45 14" CRT Monitor
My monitor displays yellowish color instead of original color
yes please take the power on self test means disconnect signal cable and monitor will give
display without cpu if display appears then monitor ok fault is in cpu if not then fault is in monitor move signal cable and look display changes or not if changes then cable faulty replace it
Nov 11, 2008 | SAMTRON 55V 15" CRT Monitor
Yellowish color from DVD
Hello Tsmith4,
Have you tried another source such as a HD cable box on the same component input (Y Pr Pb) By doing this you will eliminate the TV or the DVD player. If the picture shows great using the cable box on that same input then we will assume that the TV is ok for now. You may want to also check the DVD menu under progressive scan that it is set to progressive scan. if the picture is still not good, we would want to look at the I/O board on the TV. The red path after the Video switch maybe open. If this is the case we will have to go to board replacement. I will tell you what board to change.
Best regards
circuitcity
May 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Yellowish tinge
Hi again,
Any development(s)?
Apr 18, 2008 | Televison & Video
Monitor color has been changed to yellowish.
There are three Cathod Ray guns responsible for the millions of
colors.All colors are produced by mixing the three basic colors namely
Red Green and Blue (RGB) at suitable proportion. If any one of the
three guns fail firing then we get improper colors.
Try
(1) Simply tap on the monitor and see the result.(Keep the monitor on during this trial.)
(2) Disconnect the Monitor.and Slap it at the back by keeping it on a pillow with the screen facing down - it will resolve the problem if the failure is due to the loosening of the Head due to repeated thermal expansion and contraction.
(3) check the signal cable for loose connection, twisting etc on both ends - at the back of the CPU and Monitor (it is fixed) -
(4)tighten the screws at the backside of the CPU
Best of luck
ProfSweetlin
Sep 14, 2007 | Samtron 76df 17" CRT Monitor
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
Hitachi 43F300 43" Rear Projection Television Logo
173 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
