Question about Pioneer VSX-D510 Receiver
Overload message i just hooked this up and it reads overload the only thing i have hooked up are the built in surround sounds speakers in my ceiling. What could cause this?
  • JDinson Nov 08, 2007
    I am having the same problem newbietorres. Did changing the connectors fix the problem. I am using Monster Cable and they are hooked up to Boston CR65 speakers. As soon as I turn on the receiver it displays overload and turns off. If I only connect the right speaker it stays on and you hear the radio station. If I attempt to connect the right speaker either by itself or with the right speaker connected it "Overloads" and turns off.
    Any assistance would be greatly appreciated from anyone !!
    Thanks, John
Chnage de golden connectors (if that's what you are using) that you use to connect your speaker wiring to your speakers if they seem damaged. that's what i did
Posted on Sep 27, 2007
I had this problem yesterday. In my case the problem was the subwoofer connected in the power outlet in the back of the VSX. Switching to other power outlet solved the problem. So the tip is: check what is plugged on the VSX power outlet. In my case the sub probably was draining much energy and causing the overload in the receiver.
Posted on Dec 21, 2008
Denon receiver not working surround output
If everything is connected correct, the only thing I can think of, is you don't put in a surround signal. If you only feed 2 way stereo, only two speaker will work. Also if you switch to stereo, the other channels will stop working. Check the cables, the settings and the input.
Jun 15, 2014 | Pioneer VSX-D511 Receiver
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
I have no sound coming from surround speakers and sub.
Some surround modes switch speakers on or off as required. It's possible that the inputs you are using have settings that remember your previous settings, ie: no sub and surround speakers. Check the inputs and also make certain that whatever is connected to them is putting out Dolby signals.
May 04, 2017 | Pioneer VSX1020K Receiver
I'm trying to hook up a sharp aquos tv to an rca surround sound receiver and it won't work? any suggestions? I have tried turning off the speakers on the tv....
First thing to do is get the owner manual for each and start checking both settings and actual hookup---usually a surround system will work on all types of sets---when in doubt read the owner manuals.
If need either manual Google that model number with "manual" to try to locate it.
As far as the set goes it may require either a variable audio output source or in some cases the out to be a fixed level.
May 23, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I had seven speakers hooked up and went to a 5
check all your speakers and wiring. remove any unused cables from receiver. use the setup mic and it will do the rest
Dec 07, 2009 | Pioneer VSX-815-K Receiver
I can't get surround sound from my theatre system
Read your manual , there is a level setting for each channel as well as a test function. Also remember most media on pro-logic mode dont have to loud sound from the rear speakers. Only a forced mono mode may give you louder sound at the rear. Regards PSP
May 12, 2009 | Audio Players & Recorders
I HAVE AN ONKYO TX SR500 AV RECEIVER WITH A 5.1 BOSE SURROUND SOUND SYSTEM WITH SONY TV. MOST RECENTLY ONLY ONE OF MY SPEAKERS IS WORKING ON MY SURROUND SOUND. ALL WIRES ARE CONNECTED. I CHECKED ALL...
The symptom you described can be caused by any number of things. I always start with the output power transistors which are the first things to blow with a speaker output overload condition. Unplug the power cord to your unit, remove the top cover and use an ohmmeter to check resistance from C to E on all 10 of the power transistors (Q6050 thru 54 and Q6060 thru 64) attached to the large heat sink. Blown transistors typically read <1 ohm, compared to good transistors that are >10k ohms. If you find a bad transistor it will need to be replaced.
Jan 25, 2009 | Onkyo TX-SR500 Receiver
LogitechX540 speakers hooked them up to our PC makes raspy sound
you might try putting in a new sound card to see if that dosent help. it should take care of the problem
Jan 11, 2009 | Logitech X-540 Multimedia Surround Sound...
Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Dec 30, 2008 | Kenwood VR-6070 Receiver
Pioneer VSX-D510 Receiver Logo
305 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
