Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Convergence Today i turned on my panasonic pt-47wx53g tv. It was working just fine, picture looked good, then it shut it self off and the led on the front flashed 3 times. i downloaded t reapair manual and it says this is a convergence issue. i have found the part online, p#( tnp2aa120s)but is this a board i can easily install, and is this the only problem i should be looking at. thanks joe
Re: convergence
It's a possibility that this board may be at fault or it is also possible that the convergence amplifiers are drawing too much current and shutting the unit down. This may require replacing both IC's along with a convergence touchup, or as you mentioned, it may simply be the job of swapping the Digital Convergence board PN TNP2AA120S.
Posted on Sep 06, 2007
0 characters
3 Points
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
PT-47WX53G. TV got moved. Unable to move blue
The convergence ICs have failed which is very common when the set has been moved as a wek IC wont allow the color to be moved. You can get the PT52WX53G convergence repair kit from which is the correct one for your model. The kit contains the parts and the CD with repair instructions.
Apr 10, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic pt-47wx53g picture looks like it is 3D. What do I need to do.
Install the PT53WX53 convergence repair kit available from the kit contains the ICs, Resistors and the CD with repair instructions.
Jan 21, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-47wx53g red is out of convergence range
Have you moved the TV recently?, if so the red can(Red source) in the back bottom of the TV may have physically shifted in its holder, this is common when a rear projection tv is moved, jostled. Take the back off, look at the three cans,Red, Blue, Green, see if they all look like they are nested the same, bet the red is shifted a little.Good Luck with it!
Aug 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT 47WX53G does not turn on
If the indicator blinks three times its the error for the convergence ICs and resistors. You can get the right repair kit for your model at the following link which contains the Two ICs the 6 feed resistors and detailed step by step instructions with pictures.
Jun 10, 2009 | Panasonic PT-47WX53 47" Rear Projection...
PT53WX54J Shut Off LED blinks 3 times
3 blinks LED shows problem with convergence out ICs that either bad or not getting supplied volts from supply board to function properly.
Sep 08, 2008 | Panasonic PT-53X54 53" Rear Projection...
How many times is it blinking? That is probably blinking a code because its shutting down. Let me know how many blinks its blinking and I will be able to tell you whats wrong with your TV
Apr 12, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Have a panasonic 47" HDL projection tv..under 5 years old model # pt-47wx53g, chassis Ap 825,manufactured August 2003 Purchased Oct. 2003. Have cable service..TV works fine until 2 weeks ago. Screen...
3 blinks means the convergence circuits are shutting the set down. Usually the convergence ICs will take care of the problem, but I would recommend getting the service manual from the following link, as they will provide you free support to help you diagnose why it wont start as usually the convergence ICs wont prevent a set from powering up, unless another component in the convergence circuit has failed.
Mar 24, 2008 | Projection Televisions
How to reset defaults Panasonic HD PT-47WX53G TV/picture
First of all are you sure you were in the factory menu this step requires alot of known how!!!!!! By using your hand unit only customer controls can be reached unless you know factory menu setup. Which starts like this ,make sure antenna to cable then go to menu set sleep timer to 30 mins exit out now enter ch 124 then press v- down on tv you should now see on top CHK ,also these sets have double convergence patterens.if you were in factory set up for more information look in techassist/09-2005 .let me know if you still need help.
Nov 14, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
134 people viewed this question
Top Panasonic Projection Televisions Experts
Jaime Hernandez
Josh Whitehead
Josh Whitehead
Are you a Panasonic Projection Television Expert? Answer questions, earn points and help others
