Question about Digital Blue QX5 Microscope
Light not working
Hello, I wonder if someone can help me. Our QX5 doesn't work anymore and I think it may be because of a light bulb that no longer works. The software works fine but the image no longer can be seen. There is no light on the microscope except for a thin green light. How can we get this changed or who can I ask to do it for us? Thankyou. Kim.
bluegreenash
  • 661 Answers
SOURCE: Qx5 is not responding
the microscope may be trying to draw too much current from your USB ports, your computer will disable the device if it does this. When this happens one of the easiest (and cheapest) solutions is to acquire a Powered USB Hub (with it's own Plug top power supply). This should aleviate any extraneous current draw to the Power supply.
Posted on Sep 15, 2007
SOURCE: Cant get the microscope lights to come on
I have the same microscope, I ordered the actual disk from digital blue, was like 5 bux plus shipping, flee bay has em for 10 bux, the down loaded ones off internet are just drivers so your pc only can see
the device.
Posted on Jan 04, 2009
SOURCE: load ffdshow
The white list black list gives me the impression that this is something on your network that is not allowing it to work. My school has a white list black list system for websites. Have you tried installing the qx5 on an freestanding computer to see if that works ok?
Posted on Jan 13, 2009
SOURCE: QX5 Problem with Windows Vista
Do not plug the QX5 in until the software is installed.
I got mine to work on Vista 32bit. Insert the cd, cancel autorun, view files on the cd. locate setup.exe, right-click on the setup and go to properties; then compatibility; then put a check in "run this program in compatibility mode for windows xp" AND put a check mark in "run this program as an administrator; the click Apply and click OK.
Right-click on the setup.exe again, this time choose, Run as Administrator.
Install away from the default. My recommendation is c:\users\(your user name\digitalblue.
Plug in the QX5, then go to Start, Programs, Digital Blue, click on QX5
Posted on Mar 05, 2009
  • 72 Answers
SOURCE: i have lost my
Here are the links to the available downloads from Digital Blue:
QX5/Smithsonian Computer Microscope Drivers for WIN ME, 2000, XP, Vista 32-Bit
Download Drivers
QX5 V2 Computer Microscope Drivers for Windows Vista 64-Bit
Download for Windows Vista 64-Bit
QX5 V2 Computer Microscope Drivers for Windows 7
Download Windows 7 32-Bit
Download Windows 7 64-Bit
QX3, QX5 V1, QX5 V2 Computer Microscope for Mac OSX 10.4-10.6
Visit Webpage for Download
QX5 Computer Microscope V1 Video Codecs for 32 bit versions of Vista/Windows 7
Download Codecs
Posted on Jul 24, 2011
Reverse Light doesn't work, fuse good and bulb to.
I haven't worked on an escape, but i can tell you that switch is on the transmission.
Jun 02, 2013 | 2010 Ford Escape XLT
Some dash lights on my 01 ranger don't work.the bulbs are good
Get an Auto Electrician to trace and fix the problem. There are partial contacts in the wiring system.
Dec 29, 2012 | Ford F-250 Cars & Trucks
I have a 98 Chevy 1500, my driver side headlight was working before I went to work and when I got out it wasn't, normally I would think I just burnt a bulb, but my now when I put NY emergency brake on,...
You will need to get that one headlamp working,The daytime running light module alread recieves the signal that the light are off.And the brake switch signal is not being pick up by the daytime running light module.
Mar 15, 2012 | 1998 Chevrolet K1500
While changing the light bulb on the bottom of Whirlpool MH1140XM, the bulb popped. I replaced it but now all I get is a hum whether I push timer, light or oven settings. The oven appears to be heating...
Hello, Thank You for using FixYa. I will be helping you today.Make sure no wires were pinched in the process. The turntable motor runs off the board that's why im thinking you have a grounded wire somewhere.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Whirlpool MH1140XM Microwave Oven
I have a 89 buick century and the front left blinker is not working but all the other lights work. also i changed the bulb and it still doesnt work, can someone help?
Well, Lets see, When the Left Blinker front is not working does the bulb turn on BUT, Just doesn't blink. If it turns on and no blink You need to also, check the rear bulb.If eight er one is bad they will NOT blink. The turn indicator on the dash does that blink.. If you find all the bulbs are GOOD
Then, I recommend take out the Front bulb and look into the socket be sure it's clean no rust.
Also, be sure you put the proper bulb in. I know the 1156 bulb looks the same as the 1157.
Be sure, you installed the right part number Let me know.
Mike.
Jun 17, 2011 | Buick Century Cars & Trucks
Headlight not working fuse good bulb good no power to switch
i had the same same problem with my 1992 vulcan 750. more than likely it is your reserve lighting devive located on the right side battery box. have you had a problem with your regulator/rectifier lately or a power surge of some type?
May 19, 2009 | 1992 kawasaki VN 750 Vulcan
Digital Blue QX5 Microscope Logo
519 people viewed this question
Top Digital Blue Science & Laboratory Experts
Elton
Level 1 Expert
neil darnall
neil darnall
S J Parkin
S J Parkin
Are you a Digital Blue Science and Laboratory Expert? Answer questions, earn points and help others
