Question about Palm Treo 650 Handheld
Sync problem When I first purchased my handheld it worked and synced beautifully. I have not been able to sync since March. The communication between my computer and the device doesn't connect. I purchased a new cable and the USB port works fine with my printer.
  • Anonymous Dec 06, 2007
    haven't been able to Synch in 10 months (with my 650)
    I have two USB cables -- so that's not it
    I'm trying Bluetooth now -- but it doesn't appear to work either.
    I'm thinking something is goofed up with Windows.
    What's the best way to ensure a solid reinstall of HotSync (I misplaced the CD for the Treo)?
    Thanks in advance.
    Problem Solver:
  • 9 Answers
What are you trying to sync to on your computer? First thing you always want to check is to right-click on the Hotsync icon in your system tray (the little red and blue circular arrows) and make sure there is a check mark next to "USB"
Posted on Sep 15, 2007
SOURCE:
Hot sync
what connection are you currently using for the sync? and which version of the os are you using?
Nov 17, 2007 | Sony CLIE PEG-T615C Handheld
How do I get my handheld palm Tungsten E2 to synchronize via my USB bluetooth 2.0 adapter to my new computer that has Windows7? Microsoft windows said that bluetooth would work with Windows7,64 Bit; but I...
a. Plug the USB sync cable into a
USB port on the back of your
computer
b. Plug the cable into your
handheld
[ & ] OPTIONAL Press the power button to turn on your handheld if it is not
already on.
Continue with the onscreen instructions. Synchronize your handheld with your
computer by pressing the sync button on the USB sync cable.
Dec 01, 2010 | Computers & Internet
I had a power flicker during the time I was hot syncing my Palm TX. The hot sync did not work, and it would not hot sync at all after that. On advice from Palm's website, I downloaded the latest desk...
If so much has happened to your handheld then the only thing left to be done is a reinstall of the firmware, as that is the only solution to a corrupt firmware because of the power glitch while it was doing something. The glitch has corrupted the firmware and thats how it needs a reinstall. Nothing serious but such things do happen i electronics.
Nov 02, 2009 | Palm TX Handheld
Is MAC OS 10.5.4 compatible with
Palm was having trouble supporting but there is a new desktop available for the TX on Vista as well as Apple OS X. I don't know how well that machine will sync to both desktops though. It's probably a good idea to sync it on one machine or the other.
Aug 07, 2008 | Palm TX Handheld
HP Jornada 720 handheld communication with pc.
This error is a communication problem between your computer and the Jornada. Try these solutions:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpia2302&cc=us&lc=en&dlc=en&product=61677
Has anything changed that caused the problem, eg, installing new hardware, using a different cable to sync the Jornada?
Feb 21, 2008 | HP Jornada 720 Pocket PC
When I hot Sync my Treo 650, my tasks hot sync fails
I changed so that the desktop over-rides the handheld and the hot sync went through. This is not the way I perfer this, but it worked. I have not switched it back to sync the files yet to see what would happen.
Sep 11, 2005 | Palm Treo 650 Handheld
Error message using IrComm port
Hi, Right click on hotsync manager at the bottom right corner of the pc , make sure only local serial and ir is having a check mark , if anything else has check mark , just go to that and do a left click , it will get unchecked . On the handheld tap on home , on the main page u will see hotsync icon , tap on that , on the hotsync page make sure via ir , and not cradle or cable , then at the top u will see hotsync in words , tap on that , in the drop down u will see lan sync pref, tap on that and make sure lan sync is highlighted , and not local hot sync , since local hotsync is usefull only when u perform cradle or cable hot sync using usb , then click on ok , try a hotsync . If this doesnt help and again u get the same error , do a soft reset on the handheld and on the pc , go into hotsync manager , click on setup , choose local , change the com port to a different port and reduce the speed to 9600 , click on ok restart the pc and again perform a hotsync . The error u got was coz of this , on ur pc a ir port is not been assigned .. Try this it should work .. Regards
Sep 11, 2005 | Palm Tungsten T3 Handheld
Calendar Sync issues with Treo 650
Tryy this -- Go to Chapura.com and purchase the pocket mirror software. I have Sprint service and that additional software has resolved my synch issues.
My hot sync was working fine and now it will not communicate... I have tried everything listed on your website but nothing seems to work please help
My Palm stopped syncing on both my work and home computer at the same time. I have been syncing fine with XP and USB. I found a thread where someone mentioned getting Palm to send you a Palm Reset Card. I called Palm and they didn't offer this solution, but I asked for the Palm Reset Card and it worked beautifully! They took my call and sent the Reset Card no charge. Unfortunately, nobody at Palm seems to know about this solution.
Sep 11, 2005 | Palm Vx Handheld
Palm Treo 650 Handheld Logo
57 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
