Question about IBM ThinkPad R31 2656 Notebook
RAM What is the max ram and type?
  • IBMSUCKS Aug 26, 2007
    Thx for the fast reply!
  • 55 Answers
The max ram is 1 gb and pc133 sodimm ram. You would need 2 512 pc 133 sodimm modules.
Posted on Aug 26, 2007
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    How to Choose Memory (RAM) for Your Computer
    You need memory for your computer. But how should you choose the right kind? Whether you're upgrading your computer or building a new one, learn now.
    Step 1 If you bought your computer from a manufacturer, use a search engine or go to the manufacturer's site to find the specs on your model. The max RAM found in the specs is likely the max RAM the whole system supports. To find the largest size module the system supports, divide the max supported RAM by the number of slots. Also listed in the specs should be the max speed supported and DDR type (listed as DDR, DDR2, or DDR3). Alternatively, instead of max speed and DDR type, the specs may list something like PC# ####, where the "#" is some number. This is just a different way of representing speed and DDR type, and works equally well in finding the right RAM. If you know the largest supported module, max supported speed, and DDR type, skip to the Tips and Warnings section.
  • Step 2
    If you're building a new computer, follow the above step, except search for motherboard model specs rather than computer model specs. If you don't know the model, look for it printed on the board.
  • Step 3
    If you couldn't find your computer's specs, the info wasn't detailed enough, or you have a custom-built computer, go to (also in the resources below) and download the freeware SIW. Install and run it. On the left side, under the "Hardware" section, select "Memory."
  • Step 4
    The "Memory Summary" section on the right side shows the maximum amount of memory that can be installed in the system (listed as "Maximum Capacity"), and below that is the number of memory slots (listed as "Memory Slots"). The "Device Locator" sections tell whether or not memory is installed in that slot. To get the largest size module the motherboard supports, divide the "Maximum Capacity" by "Memory Slots." To get the speed and type, look under the "Device Locator" section, for the listing "Memory Type." Write down the PC#-#### part, where "#" is some number. Also for the listing "Speed," write down the value in parenthesis. For example, in 333 MHz (DDR2 667), write down only the (DDR2 667). You now have the largest supported module, RAM speed, and DDR type. You can use either the PC#-#### or the speed and type when searching for RAM.
  • Step 5
  • In Step 4, you found a supported RAM speed, but it may not be the fastest supported. Just to make sure, look to the left side in SIW. Under the "Hardware" section, select "Motherboard." Using this info, go to the manufacturer's site or do a web search, and see if you can find what maximum RAM speed the motherboard supports.
  • Step 6
    If you're building a new computer and need to buy RAM, look up the specs on your motherboard to find out what kind of memory it supports.
  • Step 7
    The RAM you buy should be no larger than the max supported module size, and should match the type and speed supported by the motherboard.
    Open source site for computer pc error fixing software site is on
  • on Jan 08, 2010 | Computers & Internet
    What is the max ram speed my pc can take
    According to some research, your desktop has 4 RAM slots available. The total maximum RAM your desktop can hold is 2GB (2048MB). Furthermore, each slot can hold a maximum of 1GB (1024) but cannot exceed the 2GB total.
    This means you can theoretically install 2 x 1GB RAM DIMMS in 2 RAM slots or 4 x 512MB RAM DIMMS. Both will meet the desktops 2GB limitation.
    The RAM specifications for your desktop are as follows:
    RAM Limit: 2GB (2048MB) RAM Slot Type: SO-DIMM RAM Type: DDR1 (not DDR2 or DDR3) RAM Speed: PC3200/DDR400 ECC Type: Non-ECC
    TIP: The RAM is DDR which means that while you can install them as singles (single-channel mode), the system will see a speed benefit from installing them as matched pairs (dual-channel mode).
    Aug 14, 2010 | Sony VAIO VGC-RB34G PC Desktop
    I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
    Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
    Hope this is what you are looking for,
    Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
    Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
    I have a SOYO SY-K7VTA-B, whats the max ram I can install & what speed
    Go to and run their system scanner. I will tell you the max RAM, the current RAM, the available slots, and what type of RAM will work in your system.
    Feb 15, 2010 | Soyo SY-K7VTA-B Motherboard
    # of RAM slots
    There are two models for this type of desktop, the first having only two DIMM slots, but that takes PC2700 Ram, you have stated that yours takes PC3200 which would make it the second model in which case your model has (4) DIMM slots, each slot is capable of holding a 1 GB stick of ram for a total of 4 GB. Your RAM specification is DDR PC-3200
    Jan 12, 2010 | Computers & Internet
    Max ram ??? pls help.THX
    This laptop can support up to 1 GB of PC13 type of RAM, this unit usually came with only 256 MB of RAM so you have an option to put the maximum amount of RAM for it which is 1 GB.
    Jan 06, 2010 | Toshiba Portege 3500 Tablet PC
    Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
    From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
    Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
    4 GB max 4x1024 184pin
    Hope this helps.
    Aug 26, 2009 | ASUS PSCH-L Motherboard
    Ram upgrade on Sony Viao PCVRS420
    You can use even 1 stick of 2GIG of RAM or 2 X 1GIG of RAM or any combination will do for as long it will just be a max of 2GIG since that's the max support of your motherboard....
    Oct 15, 2008 | Computers & Internet
    Upgrade RAM
  • RAM type
  • DDR2-533 thats you speed and your max is 2 gb and go to tigerdirect or new egg .com ther ar 45 a chip max
  • Jan 22, 2008 | Computers & Internet
    IBM ThinkPad R31 2656 Notebook Logo
    49 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
