Question about Samsung HCL4715W 47" Rear Projection Television
HCL4715W Rear projection blurry
Just put in a new PCB SUB because of convergence problem. Convegence is fixed, but a little blurry picture and colors are a little off. Do I need to get a tech in for fine tuning adjustments? Or is there something I can do?
  • Mark Koonce Aug 28, 2007
    The focus controls worked great, but when I adjusted the screen controls on the individual CRT board - nothing happened on all three. I turned all three dials all the way to left and right, and not change in picture at all -no response.
    Checked all connections, all plugs and wires in place. Any possibility I received a bad PCB SUB board?
    Also noticed that the focus worked great on the center of the screen, but the corners are blurry, noticed this when in the convergence mode.
  • Mark Koonce Sep 02, 2007
    Any hints on how to check and repair the 200V line.
    The screen adjustment wire directly goes to the Red CRT, then from Red to Green, then Green to Blue.
    The Red is dim, blue and green are just fine. I assume the green and blue screen controls dont work because the screen adjustment is in series, starting with the red.
    Any help on checking the 200V line and repair is appreciated.
    Novelist:
  • 192 Answers
The focus controls on this set are in the front behind the bezel. I'm not sure, but, I think on this age of Samsung, the screws to the front bezel are on the back side of the set. After removing the screws from the back, the front bezel snaps off and the door behind the bezel need to be removed. Watch the wires connected to the bezel, they need to be attached in order to turn on the set. The focus controls are on a black control block (there are three of them, one for each color). Adjust each color for sharpest picture. I use words on the screen for alignment. Each CRT board has a screen control (Adjust each slowly until retrace lines appear on the screen and then back off until they disappear). You may turn off the color and make sure that the picture is black and white. If it is not, then, which ever color is dominant, back it off a bit with that screen control. Facing the set, Red is left, Green is middle and Blue is on the right. Use only one hand inside an operating television. Do not touch the board, just the controls. This concludes television alignment 101. Any questions respond to this post and I'll reply.
Posted on Aug 26, 2007
  • Mike DeNiro Sep 02, 2007
    Screen controls not working normally is due to the 200 volt line. It may be low or not there at all. If the picture is dark, then, this circuit needs to be checked. If the picture is the right brightness is correct, then don't worry about it.
    If the convergence is correct, then, the Sub is fine. Make sure all connections are connected.
    Blurry corners are normal in a rear projection television. Your set is aging. Check for leaking fluids from the tubes also.
Double lines
Tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B are mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead to caused these problems.The tv convegence board must have be repair like repalacing parts like 2 STK convergence ICS and some or all of it resistors too.To repair the tv convergence board to solved tv convegence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 25, 2011 | Sony KP-51WS510 51" Rear Projection...
The picture started getting a triple image (everything was outlined in blue and yellow). We had a board replaced by a tv repair service, over $300 and the tv was ok for about 80 hours. (warranty on new...
Ur tv convergence board that was replaced for ur tv.The 2 STK convergence ICS was old it is not new it is those 2 STK convergence ICS on the tv convegence board is dead again and some of the resistors on the board maybe shorted and dies also must replaced too.The tv convegence board was put on ur tv those parts on the convergence board are old components parts,ur must repair tv convergence board again to fixed this problems called convergence pictures problems.
Aug 22, 2011 | Mitsubishi VS-60609 60" Rear Projection...
HCL4715W 47 in. Rear Projection Television: Wheb the TV is turned on the screen is fine, howev...
Yes,this tv can be fix it have convergence problems.The convergence board the 2 STK covergence ICS are defective and some or all it resistors are dead.The shop will cost u $300-350 for parts and labors.
May 16, 2010 | Samsung HCL4715W 47" Rear Projection...
SCREEN IS BLURRY WITH COLORS SCRAMBLED.
You can buy the new convergence board assembly from Vance Baldwin and replace yourself. Its about $80 plus shipping.
Dec 29, 2008 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W 47 in. Rear projectio
IF YOU HAVE DOUBLE IMAGES YOU CAN GO IN THE MENU AND TRY TO ADJUST THE CONVERGENCE, OR US THE AUTO JUST. ON SOME SETS IT IS ON THE FRONT. IF IT DOESN'T CORRECT THE PROBLEM THEN IT IS CONVERGENCE. I REPAIR 2-3 A WEEK. WE DO IT IN THE HOUSE, NO NEED TO TAKE THE SET OUT. MAKE SURE THEY REPLACE BOTH CHIP'S AND THAT THEY USE ORIGINAL PARTS, THE GENERICS DON'T HOLD UP. THEY USUALLY LAST 3-5 YEARS DEPENDING ON THE USAGE OF THE SET.
DON..
Jan 27, 2008 | Samsung HCL4715W 47" Rear Projection...
Internal Screen Adjustments No Response
thr focus block assy.has the screen and focus controls on it it about 3"x3" in size has red wires attached to it and one feeding form the flyback transformer to it.
Aug 29, 2007 | Samsung HCL4715W 47" Rear Projection...
HCL4715W Rear projection CRT problem
your screen and focus controls need adjustment to acheive a good grey scale picture the adjustment are not on the crt neck boards.(focus block)
HCL4715W Rear projection "Red" color is dim
screen adjustment,remove front bottom cove and find the focus block the screens are also on the same block,if your not sure don't try.
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
New PCB SUB - But blurry and color off.
have you tried to also adjust the lenses to fine tune the focus .
Convergence
Im trying to install that same board on the same tv how did you do it?
Apr 06, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
538 people viewed this question
Jerry Greenberg
Jerry Greenberg
