Question about Linksys Wireless-G WRT54G Router
232i9fwsjd98j It isn't working, It's used for 2 years and not working until now
  • iamthepro Aug 26, 2007
    Working! Like New! I dont get gay errors anymor!
  • 55 Answers
Try doing a hard reset.
Posted on Aug 26, 2007
Transcend 1TB External Drive stopped working.
Insist that Transcend replace the hard drive in accordance with the warranty.
Mar 24, 2014 | Transcend 1TB EXTERNAL HDD
Battery not charging. put new battery.still not charging.
Check the stator and voltage regulator One or both of them isn't working. Or if you're lucky, the regulator came unplugged from stator. The connecion is on the left front of the primary cover. Just follow the wires from the regulator and you will see it. Good luck!
Oct 27, 2012 | 1993 Harley Davidson FLSTF Fat boy
What happens when a knock sensor isnt working ?
If the knock sensor isn't working it isn't a real problem IF the engine isn't knocking. The sensor detects the faint pinging that comes before engine knock and sends a signal to the ECM which then begins to ****** timing until no pinging is reported by the sensor. If you do have knock and the sensor isn't working you can severely damage your engine.
Oct 14, 2012 | 1997 Infiniti.5 J30
How to shutoff ipod a1236
Turn off your iPod by holding down the "Play/Pause" button for two or three seconds. The screen should go blank, and your iPod will remain off until you turn it back on again by holding down the "Play/Pause" button.2 Let your iPod go to sleep. When an iPod isn't used for two or three minutes, it automatically goes into "sleep" mode. The screen will go black until you touch any of the controls. Sleep mode uses considerably less battery power.
  • Oct 11, 2011 | Apple iPod nano
    Even though the mouse is plugged into the CPU, the curser isn't moving on the screen. The mouse was removed from an old desktop a couple of years ago to be used on another desktop and was working fine...
    First of all what kind of mouse is it? USB (metal retangle) or PS/2 (round plug with small pins)
    USB is plug and play (meaning you can plug it in anytime even with the computer on and it should start working)
    PS/2 The computer needs to be off before you plug it in.
    Also some computers you will need to enter BIOS and enable legacy support for PS/2 mice/keyboards
    To enter BIOS, while the computer is first booting up press the key it asks for to enter setup/settings, generally it is F10, F11 or del. Look for legacy support and make sure it is enabled. Save and Exit BIOS.
    Let me know if you need further assistance
    Aug 23, 2011 | Computers & Internet
    Agitator won't spin and water won't drain during spin cycle
    Try these things first.
    1) Verify a circuit breaker isn't tripped
    2) Advance the timer control dial slowly 360 degrees-
    If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
    If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt. Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
    3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
    4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem. Go here. If the motor isn't spinning, then go here for washer motor troubleshooting.
    If none of these tips resolve the problem, then there's probably a more serious problem with either the motor, the transmission or the agitator itself. If this is is the case, call in a pro.
    Thanks for using Fixya.
    May 22, 2011 | Maytag Washing Machines
    I have the VisionPro TH8000 home touchscreen programmable thermost, which is 3 years old, and was installed with a new heating and air system. It has worked flawlessly up until this week. All of the...
    Try the screen button and clean your screen in the given time.
    also try and use the contact us. They will try to walk you through and fix the problem as an ac company will usually just try to sell you another. These are not cheap stats I use one myself, I've have mine for years. I know it isn't much but hope this puts you in the right direction.
    May 15, 2011 | Honeywell Electronic Programmable...
    95 dodge neon speedometer only works part time
    We have the same problem and it is a dash control board fault. While driving place your hand palm up on top of the steering column and push up against the underside of the dash below the speedo. More often than not the needle will pop up and start working again. If this is so then get a small block of wood and jam it in there. It's worked for our car for the last 2 years. If your speedo isn't working then your odometer isn't as well.
    Mar 31, 2011 | 1995 Dodge Neon
    Roxio burn exe file problem
    I can't find the Roxio Burn on my computer. I keep using the shortcut on desktop, but it keeps popping up that the shortcut isn't useful if not installed. But it came installed on my computer when I bot the computer a month ago, and I have actually used it to burn a couple of cd's, but I can't locate it now. What is the problem?
    May 01, 2010 | Roxio Easy CD Creator 5.3 for PC
    Linksys Wireless-G WRT54G Router Logo
    15 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
