Question about Linksys Wireless-G WRT54G Router
Wrt54g It isn't working, keeps giving me errors. ?
  • iamthepro Aug 26, 2007
    tHX AGAIN!.
  • 55 Answers
Try doing a hard reset.
Posted on Aug 26, 2007
Ge pss26sgpass keep in defrost error code bc ?????
That is actually a "tc" error code.
This error means that the display board isn\'t communication correctly with the temperature control sensors which is why it\'s giving the error. It may stop cooling so you need to keep an eye out. Either way, try to unplug the unit for 5 minutes (don\'t plug it in early it\'s hard on the compressor). Plug it back in and see if the error goes away. If it doesn\'t, you need to order and replace your display control board because it\'s just not working correctly unfortunately.Here is the board to order.
Dec 01, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
I have to daily reset my WRT54G tied to Time Warner. No problem with a separate DSL modem. Any suggestions?
Most likely you have flaky router. Coming from an Corporate IT environment, we just replace them. There isn't much you can do to fix them. You could try checking Linksys/Cisco's website for a firmware update or just simply reflash the firmware
Comment if you have any further questions and please rate this solution if you found it useful.
Nov 04, 2011 | Linksys Wireless-G WRT54G Router
When I start my dishwasher the check water light keeps comming on. Also the salt light so the machine does not go through its cycle. Can you please advise me the best course of...
Hi, if your unit is getting good water pressure then the problem is going to be your flow meter which is the device that measures how much water is coming into the unit. If it doesn't detect enough water coming into the unit, the dishwasher will hault and give you check water light error. When the error comes up look at the water in the bottom and see if you have enough water in the bottom for a cycle. If not then your flow meter is fine and your unit truely isn't getting enough water which means that either your house isn't giving good water pressure to the dishwasher, or the electronic water valve that connects to the water line from your house is bad and needs to be replaced....
Jun 21, 2011 | Bosch 18 in. SRS56L08 Logixx Slim-Line...
Linksys WRT54G: Has worked great for years. It recently reset itself (lost encryption). At same time: wireless works for about 60 secs then disconnect; then next day, wireless works perfect. Then:...
if it is working but intermittently most probably you may need to update your routers firmware online... go into your routers GUI " Graphical User Interface settigns page there should be an option for you to update the routers firmware... also try calling the routers manufacturer give them what model your router is for them to check and give you info if there are updates available for the specific router you have. if it connects it is ok it it gives an error something is incorrect in the settings.
Jun 28, 2010 | Linksys Wireless-G WRT54G Router
Linksys wireless-G with speedbooster WRT54GS2. mY CD WILL NOT WORK IT GIVE ME A ERROR 301:INTERNAL ERROR
Ok copy CD to Flash Drive and try that or go below link and download and install from that.Say download to desktop, run from there.
Feb 19, 2010 | Linksys Wireless-G WRT54GS Router...
WRT54G and PS3 not accessing online service
by default the router ip will be or or
please check this after connecting the router to your system thru network port.
by default password will be admin without any usernames
Mar 31, 2009 | Linksys Wireless-G WRT54G Router
Using Linksys WRT54G as router connected to ActionTec with FIOS
You must keep everything on the same subnet. Only allow the router to be DHCP and keep everything on 192.168.1.x subnet. You are going to have alot of problems talking across subnets
Jan 15, 2009 | Linksys Wireless-G WRT54G Router
WRT54G - Firmware Version: v7.00.1
here is the model No. WRT54G located at the lower right corner at the back of the box... and the Fw ver is 7.00.1 it is also indicated at the device it self under it... in update it in to 7.00.4 thanks
Mar 03, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
26 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
