Question about JVC AV32F577 32" TV
Bottom part of screen off and on brightness on component input
When I am using component input from DVD player or what not, I noticed that the bottom of the screen wil go bright (not too bright though, it's tolerable) and then it will go darker (back to normal) after about 10 seconds. Then this process will repeat again after about 5 seconds. This happens in a clockwork and cyclic manner. This TV is only a year and a half old and I bought it brand new. This problem only happens when I use the component inputs. I tried different DVD players but they all do the same thing. When I use the composite for the video input, everything is normal. Thanks for any help!
  • 54 Answers
You can try the other audio/video if your tv has multiple video input. Maybe your tv input RCA socket has looseboard. Need a repairman technician to fix it.
Posted on Apr 11, 2008
    Sergeant:
    Champion:
  • 375 Answers
Eprom settings are misadjusted for that mode.
Posted on Aug 30, 2007
Connecting a sony dvp-sr500h dvd player to sanyo tv. using the red, yellow, white cables that came with the sony player get me no picture, no sound. do I need additional cables? the menu on the tv screen...
Here is the quick start guide
https://docs.sony.com/release//DVPSR500H_qs_EN_FR_ES.pdf
You seem to be using the Video & Audio connection. Start at the Player. Connect cables to YELLOW Video, RED Right Audio WHITE Left Audio Then go to TV and find the YELLOW input RED input and WHITE input. On some TV's they are separate, some combine them with the COMPONENT inputs (Component is 5 cables you will use 3 of them if you only have COMPONENT inputs)
Some TV's have an input button on the remote but no on screen selection. Try pressing the input repeatedly to access the other inputs. Lastly you will not get upscaling if you are using the 3 cable hook-up. To get upscaling use an HDMI cable to connect. Be sure to not have both types of cables plugged in at the same time HDMI by itself is best. If you reply with the modelof the sanyo TV I'll try to get you more info.
Jan 05, 2018 | Cyberhome CH-DVD 300 DVD Player
HOW TO PLAY DVD PLAYER WITH THE TV
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
Red tint while using component cables
Disconnect component cable while observing screen, just to make sure that is your problem. If it is and you already substituted the dvd player and it still happens,, try replacing the cable, it may be defective. If it still happens there may be some kind of a processing defect with the component input of your tv, why not just return to RCA's
Aug 07, 2009 | Toshiba 27AF45 27" TV
Bright Blue and Green screens seem to blink.
Do not use component video. Test S video or 3 rca's red black and yellow(video) , see if they work! you need all 3 inputs on component video, sounds like you may have the colors mixed, check all color coding slowly. Sometimes the comp video out can be too strong, try using a splitter , reduces signal by 3 db, try 2 then 3 in line. This is only a test. keep in touch...
Please rate!
Mar 31, 2009 | Televison & Video
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Picture from analog tv signal is not sharp
I have this same machine, you did'nt mention what input you are using (composite, S-Video, component or HDMI) or what type of display you have (CRT, LCD, Plasma etc.).
If your T.V. has a HDMI input I recommend using that, if not and it's of fairly recent vintage use the component inputs (not to be confused with composite video inputs, or yellow RCA-type input).or at the very least use the S-Video input.
In the setup menu (on screen) try setting the "TV Screen" option to the 480p setting and if you are using the HDMI input try setting that to the highest resolution your T.V. has or set it to "Auto"
Finally in the on screen video menu select the "Video" setting and set the "Still Mode" option to automatic, and the "Output Level" to lighter or darker whatever your preference is.
Remember...Always use HDMI or component video inputs on your television (if it has those inputs)!
Hope this helps!
Joe
Nov 19, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Blue screen and menus work but hook anything and it tells me no signal
The color wheel bing noisy is a common problem iyt will eventually give a negative type picture, Loewe have now a solution to service this without replacement,I haven't tried it yet but I have one in the wirk shop to do. The second issue is probably a signal board issue, the tv handle menu systems differently from AV inputs. Loewe do part exchange prices on signal boards.
Before you change the signal board test with an AVS input from a camera or something, earlier models were sent out before Loewe had a license for HDCP and this can also cause the problem of no signal.
Jan 15, 2008 | Loewe Articos 55 55" Rear Projection...
RCA F32650 TV-Input 2 -Can I connect both Composite and Component video at same time?
I think you are right about VHS up front.......One more option =
buy a seperate video input switch box..then you wouldn't need
to use front input ........T.
Dec 17, 2007 | RCA F32650 32" TV
Apple tv
The component 1 and component 2 inputs only go to 480i and 480p. The Apple TV must be plugged into the DTV input which will accept a 1080i signal.
Aug 18, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Dvd function not working
PS is progressive scan, unless you have the player hooked up to a HDTV on its component inputs it wont play video, you need to locate button either on the front of the unit or on the remote for the Progressive Scan, this might be a good thing to look up in the manual as I dont know much about this unit.
Jul 07, 2007 | Daewoo DV-6T955B DVD Player/VCR
JVC AV32F577 32" TV Logo
32 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
