Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printing After changing my black ink cartridge, I keep getting a "Check Cartridge" message. I put a new cartridge in, but it still wouldn't print. So I pushed "Print Cancel," and now I can't get that message to go away. In the meantime, it won't print anything else. HELP! Marilyn
The ink cartridge needs to be shook up or it is defective
Posted on Oct 11, 2007
  • 20 Answers
Phisically unplug the printer and wait a minute. Plug it back in with the new cartridge installed while the printer is off.
Posted on Aug 29, 2007
My black ink ran out so I replaced the ink
Hi:
I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
Some simple things to try are :
1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
Mar 31, 2010 | HP DeskJet 960c InkJet Printer
Installing a new black ink cartridge and i keep
chech the part number of your cartriges, and also the expiration date for both cartridges
Mar 17, 2010 | HP PSC 2110 All-In-One InkJet Printer
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
Epson stylus photo 1290 'bk ink cartridge not installed properly'
Ameter:
Remove the black ink cartridge.
Check the place where the new cartridge should go. Check for a round small piece like a bushing or a little piece of pipe, stuck at the ink entrance of the printing head. This is a piece from the old cartridge, that sometimes gets loose and remains in place,and when the new one is placed, it doesnot go down to the right place to make contact with the electric connectors in the printing head.
If nothing solves...reinstall the printer drivers.
Good luck and Merry Christmas
Emiliosan
Dec 09, 2008 | Epson Stylus Photo 1290 InkJet Printer
PRINTING WITH BLACK INK CARTRIDGE ONLY; COLORED CARTRIDGE IS EMPTY.
Apparently, if you hold the "resume button" (the one next to the power button) for about five seconds after you get the message saying to replace the color ink cartridge the machine starts printing. I did this after I went to "maintenance" under "preferences" and changed ink to "black only." At first that alone did not work, but after trying the resume button for 5 secs it worked okay.
Sep 13, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
C60 says full cartridge is dry
You could try taking out the new ink and putting in the old. Then uninstall the program, delete all reference to Epson in Regedit, then reinstall the program.
Change the cartridge when prompted.
Of course, having messed about with the jet, it may not work now !
Jun 05, 2008 | Epson Stylus C60 InkJet Printer
Ink cartridge problem
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Mar 18, 2008 | Lexmark X6150 All-In-One InkJet Printer
My Hp PSC 1350v
Hi, I really appericate all your efforts to fix the issue the issue usually occures if any one of the cartridge is defective or low in ink or both the cartridge are defective. We can isolate the issue only by removing the both the cartridges out of the printer and check for the expiry dates printed on the cartridges as if the cartridges are expired also leads to this message. If the cartridge are not expired and have minumial ink in it you can try the below procedure to isolate the defective cartridge Once the both the cartridges are out of the printer insert only the black cartridge in the printer and check for the message if the message is install color cartridge the black cartridge and printer is detecting fine. If the message is check right cartridge this shows that the black cartridge is defective. If the message is insert left cartridge or color cartridge remove the black cartridge out and insert only the color cartridge and check with the message if the message is insert the black cartridge the color cartridge is working fine. And when the color cartridge is in the printer and if the message prompts to check left or color cartridge the color cartridge seems to be defective so replace the defective one will fix the issue So in isolation we can find the defective cartridge and fix the issue by replacing the defective one.. Hope this will help you to fix the issue.. Wish you success. Regards, Barret.
Sep 12, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
99 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
