Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
Dishes won't come clean
My dishwasher is just over 1 year old, it cleaned good until recently now it won't get hardly anything clean. there is usually detergent left in the door also
  • Anonymous Nov 28, 2007
    I have the same problem the dishwasher is only 2 years old and recently does not clean the dishes and theire is sopa leftover.
  • 44 Answers
If you have dishes (typically cutting boards or really tall dishes) that block the dispenser door from opening, the water cannot wash out all the detergent during the wash cycle. Check to see that after loading the dishes, your detergent door has clearance.
Posted on Sep 14, 2007
SOURCE:
My dishes come out dirtier then when they went in. I usually rinse my dishes before I put them in because the dishwasher won't clean them. I tried cleaning the two filters today and this didn't help. I...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Mar 20, 2011 | Bosch SHU9955UC Built-in Dishwasher
Poor cleaning
I found a lot of stuff built up in the spray arms and replaced them...wife is happy again... :-)
Here is a tip that I wrote about your problem...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Apr 17, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
It didn't drain > only 2 1/2 years old > and I clean my dishes good before loading etc... ?? Help
run CLR through it
check that the drain hose is clear, did you recently get a new disposal?
check routing of drain hose to disposal, do you have an air gap at the sink before the disposal? is it clear?
hard water deposits?
Sep 04, 2009 | Dishwashers
My 4 1/2 year old Bosch dishwasher won't clean.
this tells me that you have a drainage problem chk. the hose for kinks and or plugs
Aug 23, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
Film on dishes and inside dishwasher
Hi debstone
This is a common problem. what you should do first is pick up some GLISTEN and run it through on a full wash with NO dishes. the use electasol POWDER detergent and turn your jet dry down to 1. that should fix your problem. hope this helped
brent
Aug 01, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
363 people viewed this question
Top Frigidaire Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
