Question about Vulcan SG44D Gas Double Oven
Ingition module flash code
Red lite flash 3 times both burners will lite then flame fail.I think the sensors may be bad.(2) I had to jump out the 120 volt relay for 24 volts.There is no power at the relay coil from the hi lo fan #86
  • 640 Answers
It sounds like the flame sensors but both burners?i would try to clean the sensors up with emory cloth and see what happens.if that doesnt work the ignitor board is probably bad.i belive to get your voltage you have to go through the door switch then the load switch.the fan does run when you close the door right?let me know
Posted on Aug 26, 2007
Burners won't light without lighter
first off let me say that many times oil and food debris clogs the spark igniter holes in the burner. and can be cleaned with a tiny pin or small thin nail inserted in each hole
BEWARE the
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. I offer free advice bcuz God is so good!
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Jun 23, 2015 | Ovens
Trouble shoot oven
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
GAS OVENS
Apr 26, 2015 | Whirlpool Ovens
How do u light the oven
GAS OVENS
Apr 22, 2015 | Ovens
Zanussi gas cooker gas not coming through no ignition
GAS OVENS
Jul 30, 2014 | Zanussi Ovens
There is no gas flow to one of the ovens igniters
GAS OVENS
Jan 28, 2014 | Viking 30" Professional Select Built-in...
Oven not working
GAS OVENS
Nov 22, 2013 | Belling Ovens
Diplomat adp 0511 grill has no gas or ignition
GAS OVENS
Jan 18, 2013 | Belling XOU592 / XOU593 Electric Double...
Have a zephaire GL when you first turn on the
"sparks pilot lights" , "reset button comes on" can you be more specific on these terms you used? I know this posting is an old posting, but I maybe be able to help you as I have fixed all the problems (multiple with 6 G-L's zephaire. Here I'll try to "assume" your terms. The g-l has one light at the front panel. If you mean it comes on and off (the light that is), this is the due to continuous try ignition module, not reading the "flame sensor input right", assuming there is no flame at the pilot. This might be caused by a mulfunction of the ignition module, or by a bad "flame sensor wire" or sensor. See if the pilot spark / flame comes on when you turn the oven on. See if the white wire coming out of it is good and not chewed by rats or something. If the ingition control (the blue box) is reading flame sensor input right, it will light the main burners, (red wire on the valve) if I recall correctly. The ignition control works properly on max 150 F and the ventilation fan on top if it's not working should be replaced. They sell them on line, and also grainger has it for around $32. The o modules go for around $129 to 170. and sometimes you find them on ebay for around 50. Hope this helps.
H
Jul 13, 2009 | Blodgett Ovens
Spark module clicks and gas will not stay lit, flame comes on but goes out
hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
thank u.................
Sep 11, 2008 | Ovens
IMPERIAL ICV-1 SINGLE DECK CONVENCTION OVEN
this is a common indication that the ignition module is probably going bad or the flame sensor is not sensing the flame on the burners. There are other, more technical issues possible but this is usually the most common. The "not restart" , if referring to the burners, is an indication that the ignition module has "locked out" the system, usually after 3 failures of attempts to light the burners.
Oct 31, 2017 | Imperial ICVD-1-H Turbo-Flow Gas Single...
Vulcan SG44D Gas Double Oven Logo
219 people viewed this question
Top Vulcan Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Dennis Boxerman
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
