Question about Toshiba 50A60 50" Rear Projection Television
Toshiba 50a60 cracked screen
The screen on my projection television is cracked. How do I know if the cracked screen is the "protector" or the fresnal screen? If it is the protector and I can get the same size of plexiglass cut at Lowe's, how do I install it?
I have just experienced the same myself, what you need to do is find a tv the same size, it doesnt have to be the from the same manufacturer, although it helps if you can get the same, as all lenticulars do the same job.
The outer screen is called the Lenticular, and the inner is called the fresnal, depending how bad your lenticular is cracked will determine if your fresnal has gone also, the only real way of knowing is when you take it apart to change it, (Dead Easy).
they are quite close together, but dont be afraid of trying, i have never changed one before, but i did it in about forty minutes and i dont know the first thing about tvs and now it is as new.
to change it, all you have to do is unscrew the front of your tv, from the surrounding screws at the back of it, once you have done this there are four or five small screws that hold the front of it up, take these out and your front will come off complete with lenticular and fresnal.
place it face down on a soft surface, so as that you are looking out of the inside of your screen, and you will see the fresnal.
they are held together with four brackets, one on each side of the screen.
unscrew the brackets, and take the fresnal off, then the lenticular.
put your new lenticular in, then the fresnal on top of that, and then secure it together again by screwing the four brackets back on.
it really is that simple, do not let these TV repairmen, scare you into buying a screen from them and charge you an extortionate amount of money to fit it.
im not sure if plexiglass will work, i was quoted £160+VAT for my screen from Toshiba, so what i did, i went on Ebay and found a full tv that was for spares or repairs, and paid £26 for it, and it is just as it was before.
One thing you must not do when attemting to change it, and that is to be scared of attempting it, because once you have done it, and at a fraction of the cost, you like me will curse the people who make a living out of overcharging people for such an easy job!!!!
Good Luck, and hope this has helped..
Doolb
Posted on Nov 13, 2007
I have Toshiba Theaterview 50A60 projection TV ( built April, 2001 ) with a broken front screen. Anyone know where to find one??
http://www.partstore.com/ give them a call. If they don't have it, the can tell you where to get it or maybe order it special for you. Good luck!
Oct 09, 2010 | Toshiba 50A60 50" Rear Projection...
My screen is cracked need to be replaced
Your set has 3 screens:
FA812 SuperShield is no longer available
23837472 Lenticular lens is no longer available
23837450 Fresnal lens is also not available.
Check with some of your local TV shops. You may find a non-working TV with good screens for sale.
Good luck
Aug 10, 2009 | Toshiba TP50G50 50" Rear Projection...
Toshiba 50A60
Your best bet, and the cheapist, is to go on craigs list, an look for the same size tv, doesnt matter what brand, get one that doesnt work, probabily can find one free, or verry cheep, then just swop out the screen
Jan 08, 2009 | Toshiba 50A60 50" Rear Projection...
Where can i get a Screen for toshiba 42pw33p model ??
The model number 42pw33p is not a valid Toshiba model number. However, 42H81 is a valid number. The listing below is for model 42H81 ONLY! Double check you number before purchasing.
There are 3 screens that make up the screen assembly The inner screen is the Fresnal Screen. The middle screen is the Lenticular Screen and the outer screen is the Protective Screen. Please click on the links below to purchase these items.
Fresnal Screen
Lenticular Screen
Protective Screen
Mar 06, 2008 | Toshiba 42H81 42" Rear Projection...
BROKEN SCREEN
Manivain,
The fresnal screen is Toshiba p/n# 23311898, approximately $108.00 the lenticular is p/n# 23311897 approximately $95.00 and the screen protector is p/n# 23311863 is approximately $118.00 all available at Vance Baldwin 800-432-8542 or their web http://www.vancebaldwin.com/ and just click in as a guest.
Bill
Nov 29, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 50A60 Lenticular cracked.
I don't have a particular source, but if you fail to find one you may try using a similar screen fopr a different model if you're a bit handy. Depending on how the screen is fastened, you might even be able to fit a regular canvas (roller curtain type or similar, user with video projectors)
If it has to ba some kind of specific frame on it you miahgt have to "hack" it, and it might not be that pretty. If it's just a screen fastened inside a frame, kind of like the glass in a picture frame you can get one in the same size, or a bit bigger and cut it down to size yourself.
Nov 26, 2007 | Toshiba 50A60 50" Rear Projection...
Broke screen
There are actually two screens in that unit sandwiched together. The fresnal screen is Toshiba p/n# 23430635 about $165.00 plus shipping and the lenticular screen used to be Toshiba p/n# 23430634 but after two substitutions is no longer available...
Vance Baldwin is about the only outlet I'm aware of that carrys the fresnal screen at a reasonable price, just login as a guest and follow the directions to research the parts. www.vancebaldwin.com
Have a good day!!
Bill
Nov 25, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 50A60 vertical picture adjustment
Try downloading the service manual and go through the calibration excercise. There's also some additional controls behind the right front speaker.
Nov 18, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60
This are the part #s for the screens 23430784 fresnel 23430783 lenticuclar . the screen protector just measure the size and go to home depot and they can cut the plexiglass for you. to get the parts go to this link .http://www.vancebaldwin.com/
Jun 24, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60 50" Rear Projection Television Logo
155 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
