Question about Olympus EVOLT E-500 Digital Camera
Slow Shutter Speed
My e500 shoots fine in Auto but when I try to use anything else the shutter will click and the busy light will flash and finally after a couple seconds i get a picture. Why?
Check Menu second one down, Press the up button once to get you to the Anti Shock setting and change it to off. Also Check Menu second one down, Click right once then down twice, Right once. Make sure it is set for the top setting.
Posted on Dec 01, 2008
SOURCE:
Hi, the photos i take are getting blurred and the image is not at all clear no matter how shot the distance may be i click the image.the only new icon i see on the screen is vibration warning symbol along...
If you are shooting in Auto mode with flash, this should solve your problem. Make sure you are not dictating any of the settings, i.e. choosing a longer shutter speed, a very small aperture setting, or a very low ISO (sensitivity) setting.
Typically the vibration warning icon will appear when the camera is trying to use a long shutter speed without flash in order to get the right exposure for a darker scene. Your outdoor (bright light) photos are probably OK.
In dim light with a point and shoot camera, you can have your choice between 1. blurry (using a relatively slow shutter speed), 2. dark (using a shorter shutter speed but no flash), or 3. a good photo with flash (which uses a medium shutter speed and added light from the flash)
Mar 12, 2011 | Cameras
Picture from camera not clear
There could be any number of issues, unfortunately, your problem description doesn't give enough information, but here are some ideas.
Likely, the culprit is either a problem with focus or a problem with camera shake. In either case, brighter light and/or using a flash should help as auto focus works better in bright light and the shutter speed is faster in bright light. (With a faster shutter speed, there is less time for the camera to move while the image is recorded).
If using auto focus, be sure that the focus point illuminates on your main subject.
Many point & shoot cameras have an indicator if the shutter speed is too slow for a hand-held shot (typically occurs with low light). If this is indicated, then use a tripod (or brace your arms/elbows to make a human tripod) or increase the ISO of the camera (may have to go to manual mode) to avoid camera shake. Holding the camera at arm's length to look at the display while taking the picture is a recipe for camera shake & blurry pictures. You can rest the camera on a shelf and use the timer so that your hand motion pressing the shutter button isn't an issue. If using an SLR, ensure that the shutter speed is faster than the reciprocal of the focal length. That is, for a 100 mm lens, the shutter speed should be faster than 1/100th of a second.
Feb 25, 2011 | Cameras
I'm trying to take pictures without the flash but
You can shoot at faster shutter speeds if you raise the ISO setting. Also, turning up the lights will help.
Jan 12, 2010 | Nikon D40x Digital Camera
D300 long shutter delay
are you using mirror lock-up or live-view feature?
Jun 02, 2009 | Nikon D300 Body Only Digital Camera
Photos have streaks
Sounds like you are shooting at shutter speeds of 1/30th of a second or slower, and/or your flash unit is set to "slow sync" or a similar mode. Try shooting in shutter priority or manual, and using a speed of at least 1/60th but not more than F4's sync speed of 1/250th. If you are shooting a moving subject, you may find that this "problem" actually creates some very interesting effects.
Sep 24, 2008 | Nikon F4s 35mm SLR Camera
Beginner need some help please
There's absolutely nothing wrong with your camera. You simply need to learn about the basics. Read on the web about exposure, shutter speed, aperture, and how they affect each other. If your shots are blurry, the reason is that the shutter speed was too low.
How can you know when the shutter speed is too low?
- Use a tripod (the VR of the lens must be off in this case)
- Or, for hand-held shots, use shutter priority mode and set a speed as fast as the focal length of the lens. - i.e. for focal length of 100mm, a handheld shot must be taken at 1/100 sec or faster. Of course, the light might not be available for such a faster speed. The VR also gives you some latitude, but it's not panacea.
Additionally, DSLR cameras (esp. if you shoot RAW) produce images that are less saturated and contrasty compared to the blown out photos produced by point and shoot cameras.
You have a remarkable camera, just take your time and learn the basics of photography.
Jan 03, 2008 | Nikon D200 Digital Camera with 18-200mm...
Blurry pictures
There is a well documented problem with the W1 (and its brother, the P100). If you are shooting in good light, you will have no problem. If you are shooting in low light or flash, you will encounter various degrees of blurred photos. Unlike most cameras, the W1 has only two f-stops (f2.8 and f5.2). So the camera must select one or the other (nothing in between). The firmware in the camera will try to select f5.2 as long as it can in low light. This results in a slow shutter speed. And with flash you usually end up with a shutter speed of 1/40th of a second. A slow shutter speed is the cause of the blurred photos. If you can hold the camera perfectly still under low light conditins (and flash) you will get good photos. If you use the cameras manual mode and manually select a faster shutter speed you will get good photos. It appears that Sony could fix the problem with a firmware change so that the camera made better use of the ISO settings along with the f-stop selections. However, they have not done so.
Sep 08, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Blurry pictures
It is possible you were shooting in the NIGHT & PORTRAIT Scene mode. In this mode, the camera sets a slow shutter speed for the background exposure and fires the flash for the subject exposure. Since the shutter speed is slow, your subject should be still and the camera should be on a tripod - otherwise blur can result. Since this mode should only be used when the above conditions can be met, you should select PROGRAM AUTO mode for low light situations where you are taking images within six feet of your subject and the flash is required for proper exposure.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Blurry pictures
It is possible you were shooting in the Night Scene mode. In this mode the camera sets a slow shutter speed for the background exposure and fires the flash for the subject exposure. Since the shutter speed is slow, your subject should be still and the camera should be on a tripod otherwise blur can result. Since this mode should only be used when the above conditions can be met, you should select Auto or Program mode for low light situations where you are taking images within six feet of your subject and the flash is required for proper exposure.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Blurry pictures
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Olympus EVOLT E-500 Digital Camera Logo
119 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
