Question about Trendware TV-IP301 Network Camera
Problems with the IR Leds
I can't see a good image at night. Why?
Well the DUH answer is, there is less light at night. Try adding more lighting to the room you're recording in.
Posted on Nov 14, 2007
SOURCE:
Manual for a ASTAK CM 818t night vision
Your request sent directly to Astak could yield the manual.
Jun 30, 2014 | Lorex Weatherproof Color Day/Night Camera...
Bunker hill security color camera model 95914 suppose to have night vision, has the led lights that circle around the lens. Should those lights be red or at least light up for night vision? I can't see...
If the LEDS are truly for night vision only, then they are most likely Infra-Red types, invisible to the human eye, but visible to camera sensor. A way to test if they are IR and working is to point another digital camera directly at the front of the security camera at night.
The cell phone or webcam sensor will see IR LED's as white spots.
As for this model coming with night vision, I don't know.
Dec 01, 2017 | Audio Players & Recorders
What is the difference between a simple day/night IR cameras and day/night IR cameras with IR Light?
The IR lights light up your subject with light that they can't see but the camera can in order to get higher quality recordings
Oct 16, 2013 | i-rocks IR-3230 Webcam
Why wont my Night leopard light up the screen after no use for 1 year? The battery was replaced, the IR led comes on but no light on the screen. Help
Hello, it could be a number of problems with your Night Leopard Monocular. Broken wire, bad switch, cold solder joint, faulty electronic components, image intensifier tube has gone south faster than a Ethiopian chicken. Another problem here is were it was manufactured and there quality control procedures.... I would say that Russia manufacture mostly junk in their NV devises. But they also manufacture some night vision components that really good. Nothing to the quality of the US tho.
Since, I have work on a few of these Russian NV devises. 90% of the problem will the image intensifier tube. They might work for six months or six years. There quality control isn't the best in the work; of course, the companies in the USA that has there name and logo on them they tell a different story. GB....stewbison
Sep 03, 2011 | ATN Night Leopard Monocular
I dont have a manual with my paramount night vision. how do you operate it. i can get a red light but thats all.
Hello, You should have two switches, one for on/off and the other for IR intensifier (red). There should be or not two LED one green to indicate on/off--no green LED it off, if the green LED glows green it on. The same with IR luminator, red is glowing the IR is on, if not glowing red, it off.
Make sure you have new batteries and make sure that the polaity is correct---positive +,
negative -.
Push the on button, if you push the right button the green LED will glow, then push IR button. Put you hand in front of the monocular and see if there is a red glow on the palm of you hand, if there is then the IR is on. Never look into the IR lens. Now you can look through the eye piece.
Now, if there no green tent inside of the monocular then there are other problems with you NV devise.
Never, and I mean NEVER look at bright light at night or in the daylight. This will destroy the image tube. That is one reason why they are call night vision....Only for viewing in the dark. stewbison
Aug 08, 2011 | Bushnell MOONLIGHT Night Vision -...
The camera still works but when its dark in the room nothing shows on the monitor. If we turn the light on it works. It seems like the night vision feature is broken. I covered what looked like the light...
  1. It should go to automatic night vision. If this feature is not working then the answer to will a flashlight work the answer is not very well. The light will have to be on the child and a flashlight does not have much light behind it. Perhaps if you put a small lamp on a dresser that shines on the area the child is, this may work enough to keep an eye on him/her. A flashlight not so much. Hope this helps.
Regards, Tony
May 25, 2011 | Summer Infant Day Night Handheld Color...
I got a Night Guardian night vision monocular scope. It doesn't work, but you can see the red pale light on its small reticule if switched on. I dont know why it doesnt work anymore, before it is fine....
These NV monoculars and this Guardian is made by ATN. Normally what happen is the image intensifier tube has gone back to Red Star country. In other words, it gone! The reason why the IR light up is it on a different circuit and has nothing to do with the internal electronic of this NV monocular.
All this IR light does is to provide invisiable light to inhance the image on image tube on very dark/clouded nights. Someone else using and NV devise can see IR light on your monocular and vise versa to you, you can see its IR light. stewbison
May 10, 2011 | Optics
I have a Meade nightview night vision monocular. When powered up i only see a gray screen with no images at all. ir function works fine. Meade tells me that they no longer service these models. Please help
Hello, sorry, it is a bad image intensifier tube. 90% of the troubles with these Russian manufactured tubes they are not manufactured very well. Poor quality control on many of their consumer goods...junk. GB,,,stewbison
Jan 14, 2011 | Meade NIghtView NIght Vision Monocular
I have a Meade Nightview , when powered up , the screen shows only gray. IR works fine, but i get nothing on the screen at all. Meade tells me that they no longer service these scopes. I need a possible...
Hello. It seems that you have a few problems here. I am just taking a guest at what wrong with Meade NV. Broken wires, bad on/off switch, faulty electronic components, none operational image intensifier tube. Now, these monoculars are manufactured in Russian and the quailty is fair. There are a few companies in Russian that manufacture NV image tube that are very good. Not with Meade, NO, NV, Zeith, and a few others. Sorry, stewbison
Trendware TV-IP301 Network Camera Logo
51 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Duncan Mutch
Ekse
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
