Question about Bose Lifestyle 48 System
Display Stuck I have a Bose 48 and the display is stuck showing "AdaptiQ A/B ON". It will not show volume status or any other component status. Does anyone have the fix? Thanks in advance for the solution.
  • 14 Answers
Press the "Previous" or "Last" key that is right of the number "0"
Posted on Dec 24, 2007
SOURCE:
How can i unlock screen on motorola droid bionic because i forgot passcode?
This might help
Droid Bionic Stuck on too many unlock attempts Verizon Wireless Community
  • Power the device off.
    • Press and hold the Power button then select Power off
    • If the device isn't responding Remove / replace the battery
  • Press and hold Volume down and Volume Up, the press Power
  • Display shows Available boot modes
    1. Normal powerup
    2. Recovery
    3. AP Fastboot
    4. BP SBF Flash
    5. BP Only
    6. AP BP USB Bypass
    7. BP Tools
  • Use volume down to scroll to "Recovery", press Volume up to select
  • Once display shows Android triage screen, press Volume up & Down at the same time
  • Display shows Android Recovery
  • Options are:
    1. Reboot System now
    2. Apply Update from SDCard
    3. Wipe data / Factory Reset
    4. Wipe Cache partition
  • Use volume down to scroll to Wipe Data/factory Reset, press power to select
  • Display shows Confirm Wipe of all user data - This can not be undone
  • Use volume down to scroll down to YES - Delete All data - Press Power to Select
  • Device will perform format wipe
  • Display then shows Android System Recovery
  • Ensure reboot system now is selected then press the Power button to select
Oct 16, 2015 | Motorola Cell Phones
Tip
Bose LifeStyle 48 Video Mode
Bose LifeStyle 48 System Video Mode Change
Follow these steps to change the video setting from European to North American:
With the media center turned off, use the controls on its front panel to follow these steps:
  1. Press and hold the Enter button on the media center.
  2. While holding the Enter button down, press the Store button. Selections will appear on the media center display each time you press Store.
  3. When Video appears as the selection on the display, release the Store and Enter buttons.
  4. Use the Volume up and down buttons to scroll through the Video options.
  5. Stop scrolling at the proper selection:
  • For a component connection only, select:
  • -NTSC COMPONENT (in N. America)
  • -PAL COMPONENT (outside North America)
  • For a component connection and progressive scan, select NTSC PROGRESSIVE.
6. With the proper selection made, press Store to confirm the
selection and leave the Video options.
I hope that helps.
_______________________________________
Bose LifeStyle 48 Manual Download
Reset Bose LifeStyle 48 VChip Password
on May 02, 2010 | Televison & Video
Tip
I hope that helps.
on May 02, 2010 | Bose Lifestyle 48 System
Volume goes up by itself
First, check your software firmware version and see if there is an update. If available read your manual how to do a firmware update using your USB port, if you don't have a manual, check Bose.com for their online manual and firmware updates. I had a different problem but the firmware update solved it. Another tip to increase the depth of your bass, while doing the adaptiq process, cover your bass speaker with a pillow, this will make your bass more deeper. You need a second person to cover your bass module with a pillow. in this way, the adaptiq process cannot hear the bass sound and it will increase the bass. You might need to do this several times until you get the desired bass sound. If you have not setup using adaptiq, your better off not using adaptiq, the sound is much better. Hope this helps.
Nov 18, 2013 | Bose Lifestyle V25 Theater System
My Bose lifesystem 48 will not start when i start it up error 802 is showing in the display. I can her some nois (tikking) from the harddisk. i am from Norway but my Bose is from USA .I use a transformer...
Purchase a new bose mk4025gas hard drive from impact computers .com for 100 bucks and install, a monkey can take six scews out, pull back up and slide off top remove hard drive from the side of the dvd player, just pull out remove 2 screws from bottom and then pull off ribbon. install back in reverse order.
Dec 22, 2009 | Bose Lifestyle 48 System
Volume control
I had the same problem as this, but have lost my remote, so the system is know useles. Any way back to the point if you wiggle the cable around that goes in the speaker zone port then turn it off and back on then it should work :-D.
Jan 18, 2009 | Bose LIFESTYLE 28 Series III System
Lifestyle 48 Stuck Error 002
My husband left the power unplugged overnight, and by the next morning everything worked fine. Mystery!
Sep 08, 2008 | Bose Lifestyle 48 System
Lifestyle 48 locked up
Just got off phone with Bose support with this very problem during install of a VS-2 software updtae to an older LS48 system. (Bose support personnel were very helpful on phone - and walked me through procedure to solve). I presume you unplugged and replugged power supply with no resolution. In that case, unplug power supply, wait 30 seconds and while holding down the "open/close button" and the "store" button (on media center) plug the power supply back in. Continue holding until the "Bose Lifestyle" message disappears. I presume this puts the system into a diagnostic mode, as the next steps in my case were to press and hold the "erase" button while scrolling through a menu of options using the "volume up" button. I believe it was the third "volume up" press that brought me to "FLASH" on the system screen. At that point I was told to release the "erase" button and press the enter button. The system rebooted and my VS-2 install went smoothly after that.
I'd recomend calling Bose support (800-905-2138) since your lockup occured during a CD load vs a software update (just to be on the safe side) - I was talking to a live tech support person in less than 15 seconds... a pleasant surprise.
Jan 26, 2008 | Bose Lifestyle 48 System
The Media Center system doesn't work and the AdaptiQ CD (2) is in the Media Center. We can't put out the CD. There's standing on the display Bose lifestyle. Has someone the solution to the problem?
Unplug the media center power at the rear power plug. Leave off for 20 seconds. Remove the AdaptIQ headsets plugged into the AUX input. Power the system back up but leave alone for about 10 minutes. After 10 minutes come back and press the "open/close" button the wait 30 seconds or more for the tray to open. Be patient, the media center is processing a huge amount of data and needs time to respond to your commands. It is important to leave the media center undisturbed for approximately 10 minutes after running AdaptIQ setup. After about ten minutes, power down the power back up. You should be ready to go after that.
Dec 23, 2007 | Bose Lifestyle 38 System
Bose Lifestyle 48 System Logo
859 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
