Question about Bose 321GS Series II System
  • BEEZLE Aug 26, 2007
    what is output impendance? sorry I don't know much about these things being a woman, lol
  • 625 Answers
What is the output impedance of the bose system?
Posted on Aug 26, 2007
    THOMAS MIERZWA Aug 26, 2007
    speakers that connect to ANY system have a certain resistance measured in ohms. If this ohmic value isn't matched to the output, you run the risk of burning out the final amplifier in the unit. every amplifier for music or radio needs a resistance match in its final amplifier circuit. the speaker "loop" is part of the circuit.typical values of output impedances are: 4 ohm, 8 ohm etc. Look somewhere on the output unit for an impedance value.
After adding amp and sub, front and rear speakers wired to reciever will not play.
It sounds like you removed the remote wire from the factory amp to run your aftermarket amp. You need to reconnect it, and if necessary, split it to go to both.
Sep 18, 2015 | Kenwood KDC-BT555U
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
I an lg47 240 hz flat screen hooked to a bose 3-2-1. I got the dvd to play through the bose and sound working through both the bose speakers and tv speakers, but when I try to get the tv to play through...
if you are using a hd reciever make sure the audio output goes directly to the bose system... if you do not have an hd reciever make sure its audio out on the television that you are using if you do have it hooked up right make sure the bose 321 is on the right input such as audio in!!!
if it still is not working exchange it.
Nov 18, 2009 | LG 47LG60 LCD TV
I have a Bose Amas 10 III with 15pin input and 3 Blue female rca Front Center R and L and 2 Yellow female rca rear R and L is there a special rca to + and _ for output?
rca jacks by design separate possitive and negative. not sure what you are trying to do but make sure that you are not trying to hook up the bose speakers directly to your reciever, you will blow them.
Aug 06, 2009 | Bose Acoustimass 10 III System
I am planning on buying Denon AVR 1909 receiver. Can hook it up with Bose Acoustimass 6 speakers. DOes the Denon blow up the small bose speakers. If yes how do i hook them up.
on the am 6 by bose you have to use all the supplied cables or you will blow them. the way it works is that all the speaker signal/power from the denon goes directly to the sub, then the sub sends the signal to each speaker. if you do this correctly the sub takes what it needs and sends the rest to the smaller speakers. and you wont blow them unless you hook them directly to your reciever.
Jul 30, 2009 | Audio Players & Recorders
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Adding Spaekers
If it's an original 321 system (series 1) then it has an audio output on the back. (via RCA jacks) You would still need an amp or receiver to connect the speakers to.. (unless they're powered speakers)
If it's a 321 series II or 321 series III- it does not have an audio output.
If the system has a DVD tray right in the middle of the media center, then it's a series 1.
Otherwise, you'd have to get a 1/8 splitter to come from your Mac's headphone output. (still- you will need an amp/receiver or powered speakers to have both 'rooms' playing the same thing from your computer)
May 29, 2009 | Bose 3 2 1 GSX System
How do i hook my bose 901 equalizer into deno
The Bose EQ connects to the tape out and tape in on the amplifier or reciever. If you were using these for a tape deck, you will then have to connect the tape deck to the tape in and out on the Bose EQ.
Mar 22, 2009 | Bose 901 VI Main / Stereo Speaker
My TV is not compatible with plugged in speakers
yes,just buy any audio video reciever(AVR),you can use this AVR by connecting all your audio and video system,it has a built in amplifier,by using an AVR system it will solve all your problem....
Jan 23, 2008 | Bose Cinemate Digital Home Theater System...
sell your bose system and buy a real home theater surround sound system with a real subwoofer and not a Bose "Bass Module"! Problem Solved!
Dec 07, 2007 | Audio Players & Recorders
Bose 321GS Series II System Logo
150 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
