Question about Kodak EasyShare Z612 Digital Camera
Need help with the z612 set up
I bought the z612 camera without a manual and now i have the evil red eye syndrome on every picture. i have to take wedding pictures on the 31st. is there a site to go to or a download of the manual?
  • 69 Answers
Here is a link to the user manual that I found for your camera: http://www.kodak.com/global/en/service/publications/urg00512toc.jhtml?chapsec=urg00512toc&pq-path=8815
Posted on Aug 26, 2007
SOURCE:
I have a Nikon Speedlight SB-800. Before I take a picture from my Nikon D70 the flash will click about four times while there are spurts of light coming out of the bulb then the picture will take. Never...
The pre=flashes are for reduction of red eye and also for TTL indormation for camera to wotk properly with flash. Read Flash manual and some info in camera manual
Jan 10, 2011 | Nikon Speedlight SB-800 TTL Flash
I'm having a couple problems with my Nikon D90 and for the life of me that manual is too confusing, The first problem I'm having is.... I'm taking pictures at my sons wrestling events and I can't get it...
I imagine your son's wrestling events are held in school gyms with lighting that is less than ideal. If you are taking pictures without a flash then the blurriness you describe could well be due to a slow shutter speed. Your camera is using a slower shutter speed to gather enough light, but your subjects are moving fast enough to cause motion blur in the picture. Either you increase the aperture (larger aperture = smaller f number), increase the ISO number (equivalent to film speed), or you use a flash. If you do use a flash, the built-in pop-up flash is only useful for close shots probably no more than 15 feet away or so. A speedlight flash, such as the Nikon SB-400, Sb-600, SB-700 or SB-900 will project the light much farther.
If you set your ISO manually to 1250 or 1600 and put your D90 on shutter-priority (the "S" on the left dial) then you can use the right rear dial to set your shutter speed and the camera will set the aperture for you. To stop the action you will likely need at least 1/125 or 1/160 of a second. Go as high (fast) as you can--the limit will be your lens. The standard "kit" lenses are mostly F5.6 as the biggest aperture, and that is limiting without a flash or daylight. You might also try a monopod--a one-legged stand--to help steady your camera for you.
Dec 09, 2010 | Nikon D90 Digital Camera with 18-105mm...
How do I downloan pictures from my kodak easyshaewZ612 to to lap to - I do not have a manual my son gave me the camera without any instructions with it. I bought a lmemory card and have pics - but I can't...
You can get the manual from
http://support.en.kodak.com/app/answers/detail/a_id/18663/kw/z612
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Sep 20, 2010 | Kodak EasyShare Z612 Digital Camera
EasyShare Z612 Digital Camera: I bought a new 8GB memory card for my kodak easysh...
The Z612 works with SD cards, which max out at 2GB. It will not work with larger SDHC cards.
May 18, 2010 | Kodak EasyShare Z612 Digital Camera
Red eye on sanyo digital camera xacti,always theres a red eye when taking pictures,i already adjusted everything,still occuring red eye.
Do you mean your subject's eyes are showing "redeye"? This is a common problem with cameras that have the flash very close to the lens. Almost every photo editing program has a tool to remove red-eye. Check your computer to see what you have installed. In the future, most cameras have a red-eye flash setting which shoots a short flash before the main flash to close down the pupils in your subjects eyes to eliminate red-eye. You could also turn up the lights in the room...sometimes that helps.
Apr 28, 2010 | Sanyo Xacti VPC-T700 Digital Camera
I get eyes that glow white in my pictures
bubba41, You didn't mention using the built-in pop-up flash that's when you get the "red-eye" and you can set the flash for redeye reduction when it's used.  If you are taking an indoor photo without the flash, if the redeye reduction is on turn it off that would eliminate the zombie or X-men eyes you are describing. randy320sgi
Jan 10, 2009 | Nikon D70s Digital Camera
When using flash it flashes multiple times when taking picture..strobe flash
Hello
You will find that if the flash pulses slowly several times before taking the main picture you have got the camera set to red eye reduction flash, you will see an eye symbol on the display.
Check the owners manual for the method of changing this to the setting you need.
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_400si/Maxxum400siManual-Part1.pdf
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_500si/Maxxum500siManual-Part2.pdf
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_500si/Maxxum500siManual-Part3.pdf
Above are the links to download the owners manual for this camera.
Hope this helps
Sep 25, 2008 | Minolta Maxxum 400si 35mm SLR Camera
Red Eye
i have a suggestion,
you can use Picasa2 to get rid of the red eye from your pics. however, this is installed on your computer and whenever you will take pictures, there will still be red eye. Picasa2 is very easy to use and you can get rid of the red eye in only matter of seconds.
download Picasa2 here
Apr 01, 2008 | Sony Cybershot DSC-T200 Digital Camera
Z612
I returned the camera to my Temecula Costco after showing them what the pictures looked like. Then I bought A new Kodak 7.1 (Z712-IS). After reviewing the booklet I concluded it could possibly have been the scroll dial on right upper corner known as JOG dial which controls light. But, I'm not sure as I'm not willing to test it on my new camera. By the way, I love this camera. Good Luck.
Jul 01, 2007 | Kodak EasyShare Z612 Digital Camera
Kodak EasyShare Z612 Digital Camera Logo
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
