Question about TruTech PLV16320 Television
No sound hello, i hope you can help me... i bought my tv last august (1 year ago), around last november the sound started to cut out intermittenly over the period of a a couple weeks... i would be watching tv and suddenly a strange noise would sound and the volume on the tv would go out...during november though the sound would go and then come back on after 5-20 min. sometimes i would turn it off and later turn it back on and it would be fine or take a minute for the sound to come back. just as suddenly as the problem appeared it also disappeared (last november)...fast forward to the present, suddenly again no sound, only now its been no sound for over a week...i dont think any wires are loose because the tv is mounted on the wall and doesnt move and the wires hanging are only the cable box (which has the volume up) and the wall outlet plug...i dont know what to do. i hope my tv is not dead. the picture is perfect still only the sound is out...please help, football starts soon and muted football isnt nearly half as fun!
  • trose Aug 27, 2007
    thanks, but i tried all those things and to no avail...i am going to have to call someone to come and look at it it seems...thanks again!
    Brigadier General:
  • 6,966 Answers
Hi, Probably you first have to determine if the "no sound" is the TV or your source (cable box). Try another source such as a DVD player hooked to the audio/video inputs of the TV, if still no sound then you have confirmed that it is the TV, if there is sound, then it is the cable box (in some cases it may be just the cables connecting the cable box and the TV; try wiggling it a bit, might just be loose). If it is the TV, go through the routine of the setup/menu; look for audio, stereo, SAP, etc, try different settings (pls log down original setting in case no change and you have to revert back). If all else fails, try the "thump test" this will help you determine if its a loose/cold solder problem inside the TV. Give your TV a good whack at the side, top or back, if sounds comes on even briefly, it's a loose/cold solder problem, if not then you probably have to have the unit serviced by a qualified professional. Good luck and kind regards.
Posted on Aug 26, 2007
  • Louie  Role
    Louie Role Aug 26, 2007
    Hi again,
    the "thump test" is not a recommended action. Most techs would not even mention it but somehow it is performed (whether deliberately or not) by most.
HELLO I BOUGHT A 60 INCH SAMSUNG SMART TV ESUN8000, 6 MONTHS AGO, AND I NOTICE THAT IT HAS 3 WHITE DOTS. WHAT CAN BE THE CAUSE OF THE PROBLEM? I BOUGHT THE TV AT BEST BUY, DO YOU THINK THAT THEY CAN H
sound like you have samsungs dlp white spots plague, which just gets worst. samsung are aware of the problem, so you need to get in touch under the warranty.
Nov 25, 2013 | Sony KDF-42WE655 Television
I have a philips flatscreen (32PF5331 / 12) that I bought it around 3 years ago. Everytime I turn on the TV, I only get the sound then I should turn the TV on and off (sometimes 5-10 times) before I...
Hello, not positive what part you need...but it sounds like maybe the main board needs replacing. I have purchased parts many times from a company named ShopJimmy.com. I included a link to the part from their site for your model. Hope that helps!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/catalogsearch/result/?q=32PF5331
Aug 25, 2011 | Philips Televison & Video
Hello, i am trying to find out when the MDE6400AYA was made.. What year
Hello there.
You will need to write down your SERIAL number from your model/serial tag.
Example: 15114672UY...... UY is the date code. First letter is the year, second letter-month.
1980 E March
1981 G April
1982 J May
1983 L June
1984 N July
1985 P August
1986 R September
1987 T October
1988 V November
1989 X December
1990 B Jan.
1991 D Feb.
1992 F March
1993 H April
1994 K May
1995 M June
1996 Q July
1997 S Aug.
1998 U September
1999 W Oct.
2000 Y Nov.
2001 Z Dec.
2002 A Jan.
2003 C Feb.
2004 E Mar.
2005 G April
2006 J May
2007 L June
Hope that helps,
Mike
Jul 27, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
(XL-2400) Projector Lamp for KDF-E42A10, KDF-E50A10: I have a KDF-E50A10. 4 years old. Lamp went out af...
This is by far the best xl2400 site ive come across so far. Has all the details as well as replacement guide and a direct link to amazon.com for purchasing...definitely check it out if you have any questions or concerns.
May 18, 2010 | Sony (XL-2400) Projector Lamp for...
Hello, I have an RCA Truflat tv that I bought
If you can hear sound and the sound coems from your TV, try changing the volume with teh TV remote control. Your TV isn't off it is still on. Just the video board or portion is cutting out. this could be a ton of things, I would try changing out the power strip or plugging the tv into the wall directly to make sure it has enough power. other then that you can try a home brew solution like putting a fan next to your tv to cool the component that seems to be overheating and shutting down your picture.
Aug 25, 2009 | RCA Televison & Video
Philips
if you bought it under one year ago then the retailer should be obliged to either replace it or repair it. I would look into this further, ask to speak to the manager or something casue when a tv switches itself off it indicates an error inside and turns itself off to prevent further damage.
Jan 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
92 bonneville wont start.
this certainly sounds like a faulty alternator, rec recharging battery after alternator replacement
Nov 15, 2008 | 1992 Pontiac Bonneville
Toshiba regza question
because it is not 1 year old you may return it to the seller for exchange
May 28, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
TruTech PLV16320 Television Logo
183 people viewed this question
Top TruTech Televison & Video Experts
Steve Allison
Steve Allison
Joaquim Martins
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
