Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
TOP DOOR WON'T OPEN
I finally got the door open but now it won't shut - It feel like it is hitting something rubber> I have checked the surrounding rubber gaskets around the door. They are fine. It sppears the top inside is loose. Is this normal.
I had same problem this morning. Turned power off as suggested, drawer shut right away. Thank you!!
Posted on Sep 06, 2007
I had this happen once and believe it is caused by an object in the DD not letting the inside top lid to close. The top lid needs to be reset. Simply unplug the power and wait 30 seconds or so and plug it back in. This should reset it.
Posted on Aug 27, 2007
Thanks Great solution. Work all fine now. So easy, why couldn't F & P suggest this?
Posted on Oct 03, 2007
  • Robin Galer Nov 04, 2011
    I had this same problem. The door was sealed tight and wouldn't open. It happened once 3 years ago, then again two days ago. I finally unplugged it from the power, waited a while, and it opened. What's weird is that, when I finally got the door open, the top "wall" seemed loose and dropped down. I could push it up and down about one inch. Then, after about 3 pushes, it stuck to the top as it should be. Now the door works fine.
We just had the same problem. Thank you so much for posting this... we thought we were in for spending some big money! Turning the power off and on worked perfectly.
Posted on Sep 22, 2007
6ya staff
SOURCE:
A/c and heater fan when opening door has a noise like something is hitting the fan
Possibly has insulation peeling off the inside of cabinet door. Turn off power, remove blower door. Inspect wheel and surroundings. Also check insulation on door. Good Luck
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 14, 2017 | Heating & Cooling
Door ajar sensor
Its a thick pin surrounded by a rubber ring/bellows that is in the doorframe of each door. Each pin operates a switch. When the door closes it presses the pin in and when it opens the pin slides out so it protrudes into the door frame. Open each door one at a time and press in the pin with something strong like a shoe heel, this simulates that door being closed. Do it several times, till you find which switch is not working all the time. Change that switch by removing the rubber surround and unscrewing its fasteners.
Dec 14, 2013 | Dodge Cars & Trucks
2006 Honda Odyssey electric door won't close
there is a slide door control module for each door
Jan 28, 2013 | 2006 Honda Odyssey Touring
Volvo xc90 rear hatch door closed and won't open
Hold the hatch hard closed into its frame whilst pulling on the release handle. The mechanism on most cars consists a grab/release on the door and a simple metal hop at the bottom of the frame. Over time the hoop can become loose and move slightly inwards each time the door is shut. The door seal rubbers push back on the door surround putting a lot of tension against the grab/release mechanism preventing it from releasing. By pressing on the door and compressing the rubber surround you will take the pressure off the release mechanism and allow it to open when you pull on the handle. Once the door hatch is open, loosen the mounting bolts to the metal hoop and move it out about 10mm. Tighten the mounting bolts. Shut the door gently as a trial close and check for security of fit. If very slack, ease the hoop inwards a couple of millimetres. When happy, tighten the mounting bolts securely. draw around the hoop mount with indelible ink so if it moves in future you have early visual warning and can remount it easily
Jul 13, 2010 | 2004 Volvo XC90
I have an electrolux 2100 and it won`t shut off when i depress the top button? thank you
You need to replace the switch button:
Take out the bag and keep the door open.
While the bag door is still open, turn the machine upside down so you are looking at the serial number.
Pull the cord out one foot.
Use a puddy knife and put it between the rubber side rails and the **** end of the machine.
Use a hammer or malett to hit the putty knife from the back of the rubber bumber toward the bag door.
Pull the rubber bumber stright out on both sides.
Once both bumpers are out pull the lower body of the canister from the **** end toward the intake of the machine.
Once the bottom is open you can then service the motor, cord winder, switch, and all other components.
For all the parts to fix the machine visit: http://evacuumstore.com/c-69-electrolux-accessories.aspx?manufacturerfilterid=0
Mar 17, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Front electric windows have droped slightly and do not shut on the rubbers correctly
this normally happens to older cars. Check if the mechanical in the door has gone loose or lost alignment. Normally they should be following the rubber surrounding the door's frame. Also check on the gears if it is aligning with each other. While at it check if the rubber on the door frame needs replacing.
Jul 05, 2009 | Honda Accord Cars & Trucks
Locked keys inside of 2000 dodge intrepid
If you have the master key,put it in the drivers door and turn anti-clockwise.If you cannot turn the key by hand,then apply some pliers to the key and ease the key to unlock.
If this does not work,place some padding below the key entry on the drivers door and hit one sharp blow with a rubber hammer or similar and the system should open the central locking system.
Apr 06, 2009 | 2000 Dodge Intrepid
Top freezer opens when lower door is shut
This could be the door rubbers, try boiling some water and pour it slowly over the rubber,it would turn soft and wold return to the original state.
now close the door and with a hair dryer set on hot,blow on the rubber untill it seals all over.
let the door stand close for at least 6 ours...
Let me know if it worked..
Good luck.
Sep 09, 2008 | Kenmore 72073 Top Freezer Refrigerator
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
157 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Mark Davis
Level 1 Expert
Bruce Denton
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
