Question about Sony KV-36XBR400 36" TV
SOUND BUT NO PICTURE
WITH REMOTE SET MAY TURN ON WITH PERFECT PICTURE AND SOUND AND WILL OPERATE FOR SEVERAL WEEKS. THEN AFER TURNING OFF WITH REMOTE AND TURNING ON ONLY SOUND CAN BE OBTAINED.THIS CYCLE HAS REPEATED ITSELF SEVERAL TIMES. PRESENTLY ONLY SOUND BUT KEEP EXPECTING IT TO RECOVER PICTURE.
I HAVE A PROBLEM ON SHARP 21 INCHES THE PROBLEM IS NO VIDEO BUT THERE WAS A SOUND IF I PUSH THE CHANNEL UP AND DOWN WILL DISPLAY OR VOLUME OK BUT NO DISPLAY BLACK SREEN
Posted on Sep 10, 2007
SOURCE:
How do i fix a non responsive tv set?
Do the ballast first. That should get the picture back. The main board controls everything else.
Oct 08, 2016 | Televison & Video
Why won't my Vizio 42" LCD turn on?
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Apr 27, 2014 | Vizio 42 in. LCD TV
No picture, black screen.
it means the set has a problem--depending on cost to fix versus replacing it may be less to replace if set old.
Apr 23, 2012 | Televison & Video
Mdl # pn50a5601f when the remote button is pressed to turn on the tv it responds with no picture. The tv clicks twice and turns off. it will operate by it self trying to turn on approx. 8 times without a...
Try several inputs. See if you have the sam result. If you are watching with an antenna make sure all is connected and setup is set up.
Try set up for the TV with its' remote.If it works on the blank screen that means an input problem.
Mar 24, 2010 | Samsung PN50A650 49.96 in. Plasma HDTV
LG LCD TV picture will not come up, but have sound.
If your Tv does that after certain period of time you need to replace the mainboard, the mainboard is the one where you plug everything, cable, antenna, video.
May 18, 2009 | Televison & Video
TV clicks constantly, as if trying to turn on/off.
Probably a bad main board or T-CON board or both. If you're trying to fix yourself, try disconnecting the cable (LDVS) from the small board (T-CON) at top center of the LCD panel and see if it still cycles. Note, be very careful with that cable, it is very delicate. If it still is cycling off and on, then it is probably the main board. A slight chance it may be the power board also.
Apr 04, 2009 | Samsung LN-S4051D 40 in. LCD Television
Sound no picture
those are the screen adjustment controls, most likely they are turned down to low so the tubes wont power up. What happens is when you adjust them the set will continue to operate then when its turned off say overnight the tubes wont come on cause they are set to low, Try turning each of the 3 dials up just a little at a time equally untill the tubes turn on.
Feb 01, 2009 | Televison & Video
Sanyo clt1554 has sound no picture.
I have a Sanyo CLT1554 (2 1/2 years old). Has perfect sound but no picture. The picture will come after several times turning it off/on and pressing the Reset button. It is very anoing to do this evey time. PLEASE HELP
Dec 15, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
No picture or sound
If the screen displays VIDEO 1 then the set is in video 1 mode, looking for a signal on the video 1 input jacks. Press the TV/VIDEO button on the remote (or the set itself if it has it) and cycle around to the input you are actually using.
Aug 28, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Remote works but does not operate TV... no sound
The tv can be repaired by a qualified Technician,the replacement of the sensor ? should not be too expensive,the question is if the tv reacts to some remote commands or to none,if it does not reacts it could be the remote too.The sensors go bad but very rarely.Good luck.
Sep 17, 2006 | Toshiba 26HF85 26" TV
Sony KV-36XBR400 36" TV Logo
170 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
