Question about Microsoft Xbox 360 Console
Xbox 360 controller
My xbox 360 does not read the controller when i turn the controller on. the lights around the on button on the controller just flash. I bought another controller and all the lights around the on button do is flash but you cannot use the controller. does anyone know why my xbox wont read the controllers or what i can do to fix it.
Turn on your xbox 360. push the small button to the top of the controller where the headset plugs in and pust the white button by the memory card slot is at the same ti me with the button on the controller. you have to hold it 4 a lil bit. then your controller would b set to your system i had to do the same thing 4 mine
Posted on Aug 30, 2007
SOURCE:
Controller doesnt turn on but batterys are good
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Oct 11, 2013 | Microsoft Xbox 360 Controller
My controller was working one day and then stop working the next day it had fresh battery
Solutions
Jul 31, 2013 | Microsoft Xbox 360 Controller
Ho w to fix x box from controller to x box is really slow how to make it normal
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
Sep 29, 2011 | Microsoft Xbox 360 Console
How to connect wireless controller to my console
  3. Press and release the connect button on the console.
    360s_bindbtnhand.jpg consoleconnectbtn.jpg Xbox 360 S console Original Xbox 360 console
  4. Within 20 seconds, press and release the connect button on the controller.
  5. When the lights surrounding the power button on the console stop flashing, the controller is connected.
Each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button.
Jul 15, 2011 | Video Game Consoles & Games
The lights keep blinking but nothing is happening. It wont connect to the console. What should I do?
It's possible the xbox 360 controller isn't connected to the xbox 360. Turn the xbox 360 on by pressing the power button, and wait until it reaches the dash board. Then press the controller syncing button on the xbox 360 itself and wait until the xbox 360's ring lights start to spin around. Then press and hold the synch button on the controller (located near the charge port) and the controller should synch up with the xbox 360.
Mar 28, 2011 | Microsoft Xbox 360 Controller
My xbox 360 wireless controller is new and the green light just keeps falshing it will not go on to 1 or 2 player.
you may have to sync your controller to your xbox. First you hold the big X button in the middle to turn the controller on. Next, after making sure your 360 is turned on, push the sync button on the 360 controller so the lights around the big X are spinning around. you will find it located at the top of your control close tp LB (it has 3 little waves next to it) Finally, push the sync button on the 360( which is located directly to the right of memory unit B or with xbox360 s nex to the part at the front with 2 usb ports) and the lights around the on/off button of the console should spin. Eventually, your console will find the controller. hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Wireless Controller
How do you turn on an xbox 360?
Simply press the big button that has green lights around in front of your console
Apr 21, 2010 | Microsoft Xbox 360 Console
Wireless controller wil not sync with xbox 360
turn on the console. let it start up all the way. turn on the controller. on the console to the right side of the two memory card slots is a little button. press and hold it til the green lights start flashing around the power button. there is a little button on top of the controller. when the lights around the power button are flashing, press and hold the button on the top of the controller til the lights around the center button start flashing and then it should sync together
Feb 18, 2009 | Microsoft Xbox 360 Wireless Controller
Microsoft Xbox 360 Console Logo
138 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
