Question about HP PSC 2410 All-In-One InkJet Printer
Scanner doesn't work
The printer will print and copy just fine but when I choose scan it just says "Starting Scan" on the display, the Scan button flashes green but nothig happens after an initial sort of cough as if the scanner is getting ready to move across the document. I'm using the scanner with a Mac running OS X. I've tried to use it on my iMac and my MacBook.
  • Anonymous Mar 24, 2008
    will not scan
    Sergeant:
  • 390 Answers
You could also try uninstalling the printer and reinstalling it. Sometimes the printer and other options work but not one area like the scanner, due to it not installing properly the fisrt time.
Posted on Aug 30, 2007
    Scholar:
  • 53 Answers
If you've tried the printer on different PCs and still didn't work looks like there is something wrong with the scanner internally. When you start the scanner fresh, the scanning light has to move up and down the glass if it doesn't may be something is stuck on the mechanism open it and check for lose cables or dirt. Other option will be that If you bought it on the last 11 months try send it for "Manufacturer's Warranty Repair" you can call HP costumer service and ask them where you can send your unit for service, make sure you use a traceable method and keep records. Or take it to the nearest dealer and have them look at it.
Posted on Aug 29, 2007
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
Installed my Hp Photosmart printer c309a to a Toshiba (Windows 7) I am able to print wirelessly. But when i try to scan -"to computer" the screen on the printer reads !! Scan Problem-try...
Please install and run the below mentioned software to automatically diagnose and fix scanning issue:
HP Scan Diagnostic Utility
After installing this utility,
  1. Press the Power button to turn on the product, if it is not already on.
  2. From the Scanner column in the Scan Diagnostic Utility, select your HP product.
  3. Click Diagnose . The Scan Diagnostic Utility diagnoses various scanning problems, and then displays a list of results. The results display either when the tool detects an error, or when the tool completes the diagnosis and there are no errors.
    If this utility doesn't solve your issue, please revert back.
Sep 02, 2011 | HP Photosmart Premium C309A All-In-One...
Canon MP470 will print and copy but not scan
The same thing happen to me. I have Windows XP. Try using the Scanners and Cameras Wizard.
Connect the MP470 to your computer, have it on and place the item to scan onto the scanner.
  • Go to the Start Menu
  • Click on Printers and Faxes
  • On the left of the screen there is an area titled, "Other Places"
  • Under the Other Places heading, click Scanners and Cameras
  • Select the WIA Canon MP470 device(double-click) This should open the Scanner and Camera Wizard.
  • Click Next and you will be taken to the Choosing Scanning Preferences screen. Here you can select picture type. If you click the Preview button your device will scan your item and display it in the preview box. Otherwise click Next.
  • Click Next to name the file, choose a file format and where to save it.
  • Click Next and your device should scan your item.
Sep 22, 2009 | Canon PIXMA MP470 All-in-One Printer
Trying to scan, but keep getting error code 2,162,0 My scanner printer - my Canon 4370 won't scan. Printing and copying is working fine.
This works!:
noavatar_s.gif the_sunman
Rank: Apprentice
Rating: 94%, 4 votes
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!
Sep 08, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
Scanner not scanning
PSC 1401 will print but it will not scan
Jun 30, 2009 | HP PSC 1401 All-In-One Printer
Printer and copier work fine- scanner says USB not connected.
I had this same problem and it is fixable, but not the way you would probably like, though you can still scan with the printer. You just have to open the Paint program and click from scanner or camera, and then choose your printer and click scan preview, and then scan, it works just fine but its a little time consuming.
Jun 01, 2009 | HP Photosmart C4280 All-in-One InkJet...
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
Apr 23, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
The buttons on the Scanner itself will no longer work.
You should be able to reconfigure the button settings by clicking on the "Settings" button in the CanoScan Toolbox application. Although the default setting is Scan, Copy and eMail, each of the buttons can be configured to do whatever operation you choose.
Oct 13, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
HP PSC 2410 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
