I don't know what screws you have,but self tapping screws are some what tapered on the end. The taper is to allow the screw to center in the blank hole,( Hole without threads) When you start to tighten the screw it will,cut it's own threads,using a little tapping fluid or WD-40 oil will make it easier to allow the screw to cut better threads and easier to tighten down the screw. Hope this answers your question. Sincerely Brad Locke DTD. 12/04/15
SOURCE: sear ltv 10 varidrive lawn tractor
OLDER SEARS TRACTOR WILL NOT SHUT OFF WITH KEY. STARTS FINE.. ANY IDEAS WHAT TO LOOK FOR?
SOURCE: I am having problem with my Craftsman lawn tractor
try jump cables on batery if it starts u have charging prob
SOURCE: NEED TO KNOW THE VALUES SETTING FOR LAWN TRACTOR 16 HP MODEL NO 917.274350
check the solinoid on the bottom of the carb they get stuck closed so gas will go into the carb but not into the jets
