Question about Mitsubishi WL-82913 82" Rear Projection HDTV
TV Won't Turn On - Timer light flashing continuously
Had to move the TV due to room being painted and now it won't turn on. I replaced the lamp recently and checked to see if the new one is OK; seems to be. Any thoughts? Many thanks.
  • 2 more comments
  • Gizmogosnold Aug 26, 2007
    Thanks. I tried that - no change, unfortunately. The TV is less than 3 years old, so it would be tough if your comment about "needing a new television" is accurate.
  • 2hoursago Feb 06, 2008
    timer light flishing tv wont come one
  • papalee69200 Dec 06, 2008
    i need help on my t.v. we had the power out and now it wont turn on how can i fix this please!!!????? and the timer light is flashing...
  • billytally Dec 28, 2008
    i have the same issue after a power outage, tv will not reset
Try and unplug it from the wall. This should restart the computer. If that doesn't work, you should probably look at buying a new television set.
Posted on Aug 26, 2007
Kf 55e200a
if its a dlp check the light engine there is a color wheel inside it may be worn out hence stuck and needs replacement do check that the fans are all working if one is not replce it to cos these r the only moving parts
Jul 15, 2013 | Televison & Video
Well for the first guy, it would seem something came loose while moving it. Trace your power circuit to find the ecaxt problem, as well as inspect your fuse.. I'm sure its something simple and since it wont come on it has to be that it aint getting power..
For the second guy,, the reson why he baked off and said call the manufacture is caue you proberally need a MAIN BOARD... I would suggest you take it to a secon technician first and herr what he has to say before calling the company for they to tell you,,... you have to buy a mainboard and it will cost you some money ...
Jan 14, 2008 | Mitsubishi WL-82913 82" Rear Projection...
Our tv won't turn on light blinks a couple minuate and then turns read again and lamp light flashes red
A possible bad lamp if not replaced recently or removed and at least examined. What is model number and what have you tried so far?
Apr 19, 2012 | Sony Televison & Video
Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
Apr 09, 2012 | Televison & Video
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
WD-65734 Mitsubishi TV won't turn on. System reset
Are there any lights lit on the front of the TV? Have you checked for a bad lamp? When you reset the TV the timer/power light should flash on and off rapidly for 60-70 sseconds. Does that happen?
Aug 26, 2011 | Mitsubishi WD-62526 Projection TV
I unpluged the TV, move it to another room. Now, the green timing light continues to flash and TV will not turn on. I tried the reset, but it didn't work. Any quick fix?
first question. do you see the lamp from the back lighting or trying to light. check the lamp door. make sure the lamp is not blown. generally if something goes out when moved it indication something got lose or broken.
Sep 21, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Timer light did not stop flash
Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
Jul 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WL-82913 82" Rear Projection HDTV Logo
149 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
