Question about Sceptre X9G-KomodoV (Black) 19 inch LCD Monitor
Image come sometime.
My screen turned black all of sudden, like in sleep mode. So the green light was actually turning on and off, but right before the light turn off, theres the computer image that appear for 1second. So the screen still see whats going on in the computer, but it seem he cant keep it on all the time anymore. Is there any fix for that ?
  • 27 Answers
The capacities on the circuit board are failing. It’s a cheap fix if you can solder, but most electronic service centers like Frys will fix it but may cost as much as a new one. I pick these up out of the trash and fix them for less than $2.
Posted on Nov 09, 2017
5 Suggested Answers
SOURCE:
AvioriX
  • 689 Answers
SOURCE: Monitor Problem
Use ctrl+alt+ up Arrow key on your keyboard (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Posted on Jan 29, 2008
SOURCE: 17 inch flat screen monitor has trouble turning on
Make sure that the PC video output is set at 60 Hz. The LCD often will accept up to 75Hz but will not work correctly.
Posted on May 04, 2008
budmrtn
  • 11361 Answers
SOURCE: Monitor goes black after a moment
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 18, 2010
budmrtn
  • 11361 Answers
SOURCE: Sceptre X9G Komodo II. When I turn it on, it shows
It does that when attached to another PC also? Need to narrow down the problem first.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 12, 2011
My screen symtoms are a little different on my L1975NW.
I am guessing the LED power indicator blinks green then becomes steady when the screen "turns on" (shows video). The problem is most likely a failing backlight power supply. That's why there is a 30 minute delay. Try to disable sleep mode and see whether that helps.
Aug 30, 2012 | Westinghouse L1975NW Monitor
My display screen goes on and off
I find sleep mode nothing but trouble, eventually corrupts window files over extended use, go into power options, go to stand by and select never and click apply, next go to hibernate "top right" and click, make sure the check box is clear, if not! remove check and click apply and restart your laptop.
Apr 04, 2012 | Sony VAIO Computers & Internet
Dell monitor flashing green power button black screen.
Your computer is in sleep mode, a low power mode that conserves power by turning off the screen and hard drive.
Push the power button on the system and the computer will resume.
If you don't like this feature, you can turn off sleep mode in the power options in Control Panel
Jul 26, 2011 | Dell Dimension 2400 PC Desktop
Sleep mode is blinking. i cannot restart
Have you tried holding the power button for a few seconds till it restart. If that does not work try removing the battery. Once you get it started go to power options and turn off sleep mode and hybrid sleep under advanced settings.
Thanks for using FixYa
Jun 30, 2011 | MSI Computers & Internet
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Philips brilliance 200w monitor no video
nice anecdote, fixing things from far is not easy, a t.v.-technician right in front of the actual screen could tell more- but they don't come for free, alas. hope that people's idea about problem solving lead up to you fixing a problem yourself - hey this here is for free - to sort wxperts, one needs feedback! thx alot
Jul 22, 2009 | Philips Computers & Internet
My ViewsonicVP930b Monitor Suddenly Turns Off
This is a classic VP930 problem.
It is caused by bad capacitors in the power supply circuit.
Open the monitor, and look at the power board. There are six capacitors. Replace the 220uF @ 25V and the 1000uF @ 16V capacitors. I would recommend replacing them with 35V and 25V capacitors respectively.
If the serial number on your monitor starts with Q8H you could also have a bad IC on the main board. Q8 on the main board is an FET in an IC package. If this problem persists solder a wire from the right side to the left side. There is one pin that turns the IC on and off. All the other pins (per side) are soldered together. Do not solder the pin on the left side that is by itself. Just leave it. Solder ALL the other pins on the left to ALL the other pins on the right.
Remember, do this ONLY if the problem persists after replacing the capacitors AND if your serial number starts with Q8H.
Apr 20, 2009 | ViewSonic VP930b 19" LCD Monitor
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Viewsonic E53 monitor
Base on the information given to me.
I think your computer is on sleeping mode.
first thing check if the video cable is not loose connecting the pc.
because what would happend, if it is loos it would turn on and off at times.
The other thing you can do.
right click on the desktop.
go to properties
go to screen saver
click on power
adjust the time you want your monitor to shut off.
Dec 06, 2007 | ViewSonic G90fb 19" CRT Monitor
Sceptre X9G-KomodoV (Black) 19 inch LCD Monitor Logo
77 people viewed this question
Top Sceptre Computers & Internet Experts
Ben Slimene Aymen
Ben Slimene Aymen
Arnie Burke
Arnie Burke
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
