Question about Nextel i930/i920/i870 Stereo Headset [OEM] NNTN5774A Headset
MATER RESET i870
My phone was mothly but i switch 2 prepaid now i have 2 get service i just need the 6 digit number 4 reset my phone
  • cpunet Dec 01, 2007
    Nextel i870 phone vibrates when power button pressedinstead of turning on
Posted on Nov 08, 2007
6ya staff
SOURCE:
I need a reset code for phone screen locked
There's no hard reset on this phone. Here's what you want to do. If your phone is currently locked on your home screen pres 111111(do not press unlock because it'll only give your 4 spaces, just do it until you see the 1's appear). You should see Options or Service appear,if Options, select options then service, if service select service. You should see reset lock, select it then click yes. It'll ask you for a 6-digit code. This is called the 6-digit service programming code or SPC, just call MetroPCS' customer support and have them give you the SPC, once you've entered it, your phone's lock code will reset to 0000 or the last four digits of your phone number. If it'snot locked it'll be easier for you to enter 111111 on the home screen. Follow the same procedure.
Aug 28, 2013 | Kyocera wild card Cellular Phone
Forgot sec code on my prepaid phone want to reset it
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 29, 2012 | LG VERIZON VX3200 Cellular Phone
Ulocking dora 615 prepaid locked in optus,need to unlock network
Aug 05, 2012 | Nokia Cell Phones
How to reset a lg chocolate touch phone
***This will delete all your data and bring back the phone to factory default status***
MASTER RESET:1. From the main screen, touch Menu.
2. Touch Settings.
3. Touch Phone Settings
4. Touch Security
5. Enter Phone Lock Code(default is last 4 digits of phone's number)
6. Touch Reset Default
7. Touch Ok
8. Touch Revert
Aug 24, 2011 | Cell Phones
How to factory reset a lg chocolate?
    The LG Chocolate mobile phone by Life's Good (LG) is used through Verizon cellular phone service. The Chocolate, also known by the model number VX8500, comes in a variety of colors and includes features such as a camera and a music player. The phone can be reset to factory default settings.
    Instruction
    1. Access the menu by pressing the "OK" button.
    2. Lightly tap the backwards button--the one with two small triangles pointing to the left--on your keypad.
    3. Press "OK," and then the number "5" button twice.
    4. Type in your lock code, a 4-digit pin.
    5. Choose "Reset Default" by pressing "3."
    6. Read the message on the screen and press "OK."
    7. Choose "Revert" by pressing the number "1."
Dec 07, 2010 | LG CHOCOLATE VX8500 Cellular Phone
Trying to factory restor my lg 9800 but dont have security code since I bought phone used how can I reset to erase all the previous owners **** ?
1 - Open the Flip
2 - Press MENU >> Then ' 0 ' [ zero ]
3 - At the Service Code prompt enter six zeros
4 - Choose option 12
Phone should REBOOT and RESET to Factory Defaults... But, if you want to go to the pre-activation stage, that's a different process...
1 - Flip Open, Press Menu
2 - Press 0 followed by 000000 [6 zeros at the Sevice Code Prompt]
3 - Choose Option 1 [ Service Program ]
4 - Click the OK soft button [brings you to the * Phone Number (MDN)* screen]
5 - At that screen enter 10 zeros - to replace your current phone number
6 - Click the OK soft-button
7 - At this screen repeat step number 5
8 - Now click END
Phone will REBOOT by itself and the screen will now display " Initial Programming Required " - This is what the Sales Rep sees when he/she opens the box and boots the phone the very first time to program it to your account
Nov 25, 2010 | Cell Phones
It is prepaid tracfone and some how i disabled the prepaid service on it and i cant unlock the phone or sims card either one
Here's what I did:
1. go to www.tracfone.com
2.click on service and support.
3.click technical support
4.enter your phone's serial number (you can get that by clicking on your phone's prepaid icon, then scroll down until you see serial number.
5. Click select
6. write down the number
7. On the Tracfone serial number box, write your serial number.
You'll then have to fill out a brief form (name, address, phone number, email, nature of the problem).
8. Tracfone will send you an email with simple instructions on how to reprogram you phone. It's usually just a matter of clicking Code Entry Mode and entering the codes Tracfone tells you to.
All in all it's pretty easy and a whole lot quicker than calling tech support on the phone.
Hope this helps someone
Aug 17, 2010 | Cell Phones
Need to do a master reset on a nextel motorola i870
Press, in order in a row # * [Menu] and the screen will change from asking the lock code to asking for the security code, which by default is six 0's.
May 28, 2010 | Motorola Mobility i870 Cellular Phone
I cant unlock my alltel prepaid phone
it might be the last four digits of your phone number.
Mar 20, 2010 | LG ALLTEL AX145 Cellular Phone
What is the 4 digit default lock code or phone lock of motorola L6???...
please e mail me... [email protected] ....what is the default lock code of motorola L6.. im not talking about the 6 digits code or (000000)... example: when you want to lock the multimedia it requires 4 digit only... I already reset my phone.. (master clear and master reset) it requires the 6 digits code (000000).. I was expecting that the 4 digits code will be returned to default.. I tried (1234), (0000) and (1111 to 9999).. all I know is the default 6 digits code (000000) to reset my phone..
Feb 21, 2008 | Motorola Mobility L6 Cellular Phone
Radio Communications Logo
807 people viewed this question
Top Nextel Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Nextel Radio Communication Expert? Answer questions, earn points and help others
